bigshot
That's because we are making recordings designed to be heard by human ears!
Do you have an example of that?Mastering that reduces the dynamic range of a symphony composition to that of a pop/rock piece is not what I'd call good mastering.
If you didn't have those meters your chances of recording what *is* would be minimal at best.I want to hear what *is*, not something all slick and over-produced. And meters in a DAW or on a board help keep you from clipping or distorting.
As an engineer I take strong exception to your generalization.That would explain your "use your ears" statement. They all say that - mixing engs, mastering engs, producers: "Ignore the numbers".
I don't have to ask if you've ever produced a record! Clipping or distorting are the least of the problems to solve.
Come on. Do you really think any producer or engineer would think that related to classical music?By that are you suggesting those two are ok/justifiable?
Are you drawing that conclusion based on the misuse of the DR meter function, or some other way?
Both are easily avoided, and that's like recording 101...first thing you learn. Non-issue.
So, just arguing are we?
You're using the DR meter for something very different than it's intended purpose, so your conclusions are wrong. And this is not the first time that fact has been posted.I stated such example earlier in this thread. I had mentioned that both the first movement of Beethoven's Symphony #5 on CD, and a typical '80s pop tune on CD, registered a DR=12 in Foobar. If you need visible proof of that I can add screen shots. Both CDs were original '80s releases by the way - not reissues or "remasters". Listening to both, that is, "using my ears", led me to assume that the Beethoven selection would naturally - logically - return a significantly higher DR value in the Foobar software than the pop-rock song.
You misuse it by trying to use it to determine total dynamic range of an entire symphony when it's purpose is to determine relatively short-term dynamic range as it relates to aggressive "loudness war" processing that affects crest factor. Its integration time of the DR meter is much too short to include an entire Beethoven symphony. Way too short. There are other tools, for example the "Amplitude Statistics" tool found in Audition, which would give you results you're looking for, so long as you understand which parameters to be concerned with.How does one "misuse" Foobar2000 Dynamic range meter? You drag the songs you want to analyze into the Foobar interface, right-click on the songs you want to check, and select 'Dynamic Range Meter'. A snapshot is then produced and a text document of the DR results is saved in the specific folder the song resides in. Simple! No settings to fudge with, no code.
