amb
Member of the Trade: AMB Laboratories
- Apr 1, 2004
Compensation caps must have good HF characteristics, multilayer ceramic and silver mica types are both appropriate.
Originally Posted by steinchen Glimmer caps are in fact Mica caps. [...] |
Originally Posted by amb Actually I think it's just the opposite... you would use less capacitance if the gain is higher. |
Originally Posted by SnoopyRocks Could some kind soul recommend sockets for transistors, preferably with a mouser or digikey part number? Something similar to what dgardner uses here would be great. |
Originally Posted by SnoopyRocks Now that I've finally found some free time Could some kind soul recommend sockets for transistors, preferably with a mouser or digikey part number? Something similar to what dgardner uses here would be great. You can stop thinking - you're right. |
Originally Posted by Pars The sockets that Dan used for the FETs are actually Zig Zag sockets, something like Digikey ED2220-ND (MillMax). I got a couple of samples of the 28 pin version of these, and they are easy to cut apart into 7 pin sockets, and fit better than 2 rows of SIP sockets do. The SIP sockets I used are the MillMax, Digikey part ED7064-ND (64 pin). I like these better than the other SIP sockets I have tried (Aries). On Dan's boards, the middle of the 3 pins for the FETs does not have a hole, so really you need (2) 3 pin (2-1) sockets, or you can drill a hole for the middle pin, or just clip the tail on that one. |
Originally Posted by Pars The sockets that Dan used for the FETs are actually Zig Zag sockets, something like Digikey ED2220-ND (MillMax). |
Originally Posted by palchiu Finish my first DIY headamp, but questions is how to measure and adjust. I follow measure with this diagram, I've adjust the voltage as this. But, I measur the output there were different voltage from left and right. Any one can help? Thanks!!! |
Originally Posted by dgardner Dynalo - Detailed Construction (dgardner 5-7-2005).doc (2.59MB) Dynalo - Detailed Construction (PARS Edits).doc (2.57MB) Dynalo - Detailed Construction (STACKOFHAY Edits).doc (2.61MB) Dynalo - Operating Points.pdf (131KB) We are now entering the community editing phase of the project. |
