screamsaver
- Feb 16, 2016
Hi WindowsX,
Any news for fw LX v1.4.2 ?!?
Alright. It's done now. Aside from updating to 1.4.2, I also added storage optimizations for better performance.
This mod will have the following changes below:
-Based on official version 1.4.2
-Change fallback font to Helvetica Neue and use Nimbus Sans Global Light instead of Bold
-Optimized ROM configuration for better performance
-Optimized storage performance
-Optimized video rendering performance
-Removed audio effect engine completely
-Removed Equalizer feature
-Removed unused binaries and library files for smaller footprints
-Removed video components in particle components configuration
Download: http://www.mediafire.com/download/gayj9aaapdqde0v
Your DX80 should have DSP-free playback engine now. Let me know if you notice any changes in audio performance with this mod.
Regards,
Windows X
Regards,
Windows X
Yeah. EQ is removed. This is purist mod for purist audiophiles with more inner fidelity.
Regards,
Windows X
I never use EQ but if you don't use it how is it affecting the sound? What does DSP free mean? The font is the same as the stock FW. Was it supposed to be changed?
Hi WindowsX,
thank you for your hard work!
I am new to this, so I may be asking something stupid.
How do you verify if I have done it correctly? I downloaded the file, unzipped. The file name is update_original.img. And the file size is exactly the same as the one downloaded from ibasso. Is this correct?
Thanks in advance.
Unfortunately it seems all coding in a given firmware has an effect on the sound, even seemingly unused code, I'm not sure of the scientific explanation, but there surely is one given the audible difference. WindowsX is simply removing the code for the EQ etc, and this is having an effect on the sound. It is the same phenomenon as the WAV only QA360 firmwares, simply by removing the code for reading mp3 and flac the WAV only firmware sounds different (better). Basically it is showing us that the more bare bones and streamlined the firmware code is then the more transparent it will sound. This is why I'm so conflicted about new daps that use big operating systems like android, and what it might be doing to the purity of the sound. Daps like QA360 and Tera remain the only dap's who's firmware has been purposefully designed to be as bare bones as possible with the intent of best sonic quality.
What really bothers me is that I'm sure other dap makers are aware of this effect that firmware coding has on the sound, but none have yet to try and design a bare bones firmware like QLS has for their dap, and we are left to scrounge for custom firmwares like the one OP has done.
Yes but I don't find the sound improved.
