Yes, mango is my favorite music app.Did you use Mango Player? Then try another player: Hiby, Neutron, UAPP, and compare.
Why should I try another? I think it won’t help to calibrate battery)
Sorry..Got a brain drop..here in english
Hi Whitigir,..or any other.
A question,..If you are really honest,which DAP do you think have the best music-quality...
▪ Sony NW WM1Z
▪ DX200
▪ DX200TI
And after that question,..How far apart are they in %,..if you speculate a bit freely.
/Peder
Does anyone here use a secondary DAP to the DX200? Anyone prefer something a little more pocketable for on-the-go use?
if you enjoy DX200, then why not get DX120 on the go?
I use A&K SR15 which fits my pocket easily paired up with Spartans that can go anywhere.
I then use ak100ii or phone like lg or vivo.
Follow https://github.com/Lurker00/DX200-firmware/blob/master/README.md#recommended-settings-for-neutron-music-playerHas anybody noticed, since the Oreo upgrade, the Audio Hardware page in Neutron player nownow states 44khz and 16bit being the maximum where previously it was much higher?
It comes with amp1 any further amps you need to purchase yourselfIf Im going to buy this DAP do I need to buy the AMP modules?when i saw the price wow its kinda expensive?do i need you buy it if I only use iem's?
What I mean is is it necessary to buy those dap to get the best out of the iem?It comes with amp1 any further amps you need to purchase yourself
If there is any way to calibrate dx208 battery?
I upgraded to Oreo+latest Lurker’s patch, fully charged it, chose 16bit flac album, set volume to 90 and started continues playing. After 7.5h of playing the battery was 16%.
But after next 20 mins my dap was off.
When I powered it the battery showed 0%.
