During the time I am modifying the device, I am very surprised to see the quality of the boards And the rest of the components. It is very good
The back is a thick Corning Glass, and you will need to have proper tools to take it off. Similar to how you would work on it from repairing smartphones screens, only that this is easier
Disclaimers: You are assuming all risks and responsibilities for your own device. Tampering with your device will void the warranty by any manufacturers standards, and I can not be held responsible for whatever damages your device
So, here we go. The primary reasons to modify the MAX for me is simply to get more “meat”
. There are 2 parts that I am going to do
A/ Hardware tunings and upgrades
B/ Heat dissipation
Within the part [A/] we will have 2 parts: Main and Amp. The main is following Dx220 Main EX, and so the pictures is borrowed from
@EggofSound . My thanks to you!
Hardware
MaxEX
You will need
https://www.mouser.com/ProductDetail/80-T543B107K010TE150
3x of those
https://www.mouser.com/ProductDetail/80-T543B227K6AHW35
2X of those
https://www.mouser.com/ProductDetail/80-T520A226M10ANE080
2X of those
https://www.mouser.com/ProductDetail/80-T520A107M006AT
4x of those
https://www.mouser.com/ProductDetail/80-T527I476M06ATE200
4x of those
https://www.mouser.com/ProductDetail/Rubycon/10ZLG100MEFC63X7?qs=T3oQrply3y9/QyWNcdIfTA==
2X
This is done similarly to the portable little brother Dx220, with the exception of 2 extra electrolytic capacitors. Please be sure to have battery clearances (picture shown the E-CAPs being upgraded before the rest due to progressing, I recommend to do it all at once)
The AmpMax will receive the Upgraded and improved buffering stages together with a different tuning to bring about the characteristics that in my own opinions and experiences are to be good. This buffer is upgraded for the amp-out parts only
It will improve 2 sections that I observed
Linearity which results in thinner timbres density, also the sub bass is too fast and fall down on it faces.
You will need
https://www.mouser.com/ProductDetail/584-LT6203XS8PBF
2X
8x
https://www.mouser.com/ProductDetail/Elna/RFS-10V470ME35?qs=/ha2pyFaduhr6IZ36xIzc1lr8hMSeC0PLnuOibKLJ/8264tYSkWq1b9mUTm6it%2B%2B
4x
https://www.hificollective.co.uk/catalog/330uf-16v-toshin-jovial.html
3x
https://www.hificollective.co.uk/catalog/neotech-gp-oag-26-gold-plated-silver-wire.html
1m
Small Tantalum caps are removed like Amp8EX at green lines
Purple lines are New Buffers for Amp Out
Blue wires are Power supplies and will be upgraded by Silver Goldplated wires with 2 wires per terminals. Please check continuity and make sure to have not messed up polarity
Black wires are Bus for charging, batteries informations to be displayed in the system. It will remain the same
To further improve the pitch black background.
Noises are radiated from the screen and directed back into the main board throughout,
using copper foils with conductive adhesive and make sure to have a good grounding onto the chassis to shunt the interferences.
Clear electrical tape on top for safety insulation
Batteries packs will also need TDK sheets to applied on in order to absorb strays noises, and shielded over with copper foils which is grounded to the chassis back plate, following with clear insulation tapes. The Black batteries body doesnt allow me to take clear picture, but it is underneath the copper foils
https://www.mouser.com/ProductDetail/810-IFM10M25BB300200
1 sheet
Heat dissipation
The next steps are to properly dissipate the heat generated from the DAC Chips ES9028Pros and the main CPU chip. I noticed while I was working on the Dx220EX, and also from collective firmwares inputs, the Dx220 Rockchip is capable, but because it gets hot, so it got the firmware to downclock it and make it slower. So helping to dissipate the heat will help, and possibly support the future more aggressive firmwares.
I used the thermal sheets
1000W/m-K After the applications, heats are being distributed toward the main big Chassis more even throughout
https://www.digikey.com/products/en?keywords=P14473-nd
These sheets were cuts carefully (it is easily damaged) with insulation on top of the components on the board to prevent “short” Kapton tapes would do. I used the one that comes with the main boards.
Please be careful that these sheets
Remnants are conductive, make sure you don’t leave any debris around
