What I'm reading is very far from small steps that can be traced, and reading isn't seeing. It's barely an outline and clearly requires a good deal of knowledge, unless I've missed something. Edwardsean then refers to TDK and GRP that I do not see prior (if TDK is the sheets that limit noise I see that but uncertain what the application steps are). Overall there's very little information from the perspective of someone who is unfamiliar with everything. The only thing that might suffice is the ground part, and I'm not quite sure whether I'd only be sanding the things on the plastic cover. The good thing is the dap itself doesn't need to be touched so that portion is removed. With the information available there's no way I'm attempting this. I'd only screw up my amp or waste my time. I think a comprehensive full length youtube video would be best as writing and using images would be inefficient. I very much wonder how many functioning amp8EXes are out there.
With a good full length video maybe more people than myself decide to attempt this mod. Then we can happily wait for iBasso's amp15, if not 19.
What is in this thread is all of AMP8EX.
Just follow the instructions for AMP8EX presented by Whitigir at the beginning.
It is not a summary but a clear instruction.
You may be dissatisfied with it, but this thread is for people who can understand the instructions given.
It is your freedom to demand what you think is missing, but it is your freedom to respond.
If you have questions about specific parts, it will be easy to answer.
I think we can help each other with our know-how.
Since you are an AMP-related newbie, no one can respond if you complain that you are not satisfied because you do not have the information I need.
In the information you need
・ Soldering knowledge and experience
・ Knowledge of AMP to read PCB pattern
・ Understanding sound quality for parts
I think communication is easy if it is more specific.
At first everyone is a beginner and gain valuable experience and knowledge through failure and learning.
It's a way for everyone, with no shortcuts.
The necessary information about AMP8EX is in this thread.
You can ask questions to gain the necessary knowledge to run AMP8EX.
You may think that "you need something more systematic and easy for everyone to understand."
(It may be an explanatory video about remodeling)
If you need something that does not exist, it is your job.
DIY is free at the person's own risk.
Welcome to the world of AMP8EX.
