edwardsean
- Jul 7, 2006
I use 99% isopropyl too. Is there benefit in using Flux off in addition to the alcohol?
Ah I see, are all amp modules discrete or do some use op amps?AMP8 supposed to be discrete module (no opamp) ...
Thats interesting, has anyone cracked open the amp 1 module and taken a look at its circuitry?Only AMP7 and AMP8 are advertised as discrete amp module.
If it uses op amps then maybe one can replace the built-in ones with the op amps of their preference.
Dang, that's a mighty impressive collection you have there.Hello.
iBasso is carefully implemented with OPamp and circuit review.
I do not exchange OPamps because I think it was decided after a lot of time and testing.
I have evaluated a lot of OPamps up to now, but to get good sound quality and performance, it is necessary to change the phase compensation and other appropriate circuits for each OPamp.
An OPamp with similar characteristics is only a success if it is a simple exchange.
(OPamp of the image is a part of it that I evaluated, but it took about 2 years for the individual)
I think exchange of OPamp is necessary separately from this EX thread.
And yeah, it makes sense that ibasso would have picked what they though was best for the amp module. Being able to swap op amps would be kind of fun though.
One question, would it be feasible to solder dip 8 sockets to the Soic 8 on the audio board? I may get an extra amp 1 MK2 to perform the mod if its possible.
Yeah, that's why i was considering getting another AMP 1 MK2 module so I can drill holes in it for clearance.AMP is a multilayer board very small and OPamp is mounted on both sides, so it is impossible to mount a socket.
There is no alternative but to replace directly, but it is technically difficult because other parts are densely packed.
(I am waiting for the arrival of DX220, so I do not know about the actual AMP1 MK2)
Please judge the PCB of AMP by yourself.
Yeah sorry for the OTAmp modules from Ibasso is 2 sided design. Anything involving a drilling through will damage the amp. Unless you understand the schematic and can read the traces well enough to avoid thrilling the top through the bottom without cutting off or shorting any traces.
Such ideas, even myself, and I understand both schematic and traces very well, with some experiences in amp making.....don’t even want to think about
I am with @EggofSound here, the EX is to extract the most out of stock design under extreme modifications. Rolling op amps should be on another thread, and even so, it would require lab equipments to make sure no funky and funny oscillations going on at any given sweep
Just to confirm, there is solder mask on the PCB right?
