Apparently a DUNU rep may have mentioned in passing that the Titans required burn-in. Spyro actually went out of his way to inquire - especially after the figure of 200 hours seems to be making the rounds
. Here is his post:
It actually makes even more sense if they are Titanium coated drivers. But sadly it won't stop the usual people forging along with claiming hundreds of hours burn-in required, and it also won't stop the susceptible believing it and perpetuating the myth.
Interestingly enough - the Havi B3 Pro1 was another earphone that was supposed to change after hundreds of hours of burn-in. I was fortunate enough to have a brand new one and a much older one at the same time. I queued both up, same source, same files, volume matched (didn't really need it - because both of them were within 0.3 dB at 1 kHz) with a proper SPL meter and used a splitter so I could switch quickly. No difference.
My conclusion - unfortunately you'll never stop the "phoolery" on these forums. Most of the time its easier to ignore it. Less pointless debates. Still grates me though when I see someone who has "read about burn-in requirement" then tell someone new to the forum that it is required, and yet another misinformed Head-Fier is born.
