MorrisL
- May 7, 2014
Well if the 8k peak is you only real gripe with the 990, you could always try some eq. I personally don't use this as I was experiencing some distortion problems even after taking precautions to prevent clipping, but I'm sure with a proper eq and not a crappy 10 band graphic you could tame it to your liking.
I seem to have developed an irrational fear of eq recently. I know it's irrational considering the amount of eq the music is likely processed through during mastering and before it even reaches our headphones. Some eq should really be no problem and I shouldn't feel bad about using it. But I seem to hear some distortion, nonetheless. Not sure if it's real or if I'm imagining it. Something about it just doesn't feel right.
By the way, I just uploaded some violin recordings into Adobe Audition and... man, oh man! That upper string on the violin (the open E string) is right in the middle of the 990 treble peak! And it can cut through your ears like a knife! Over the weekend, I am definitely going to experiment with some felt, some random fabric, paper towel and whatever I can find to safely dampen that harshness without losing the sweet bass.
