crazyspike
- Jun 18, 2013
Hey all, names Brian and I could really appreciate the knowledge you guys have to share.
Ive been getting more and more into listening to music over the last year or so and have looked here frequently for advice and most of the time I have found it, but after reading numerous threads I feel im pretty stuck and could really do with a bit of help.
When listening to music through my DT's from Ipod touch or Phone I found that the mids really clipped bad at high volume, bass sounds great by itself as do highs but when a lot is going on together it seems to clip like crazy.
I thought maybe my Phone and ipod were underpowered so I tried my AV receiver which was no better, ( after reading on here that headphone out on receivers is normally crap) I decided to buy a Fiio E7, this cleared up the sound and made things a lot clearer but at reasonably high volume once again I experianced pretty major clipping, yet plugging in a cheapo pair of IEMs and I could crank it through the roof to ear damaging levels, I have now purchased a Mont Blanc E12 thinking maybe the E7 was underpowered to drive these headphones even though they are supposed to work well of the E7.
you guessed it no difference as soon as the volume gets to a certain point, and its not crazy loud my headphones clip like mad.
I have just stripped the DT's down to install a dual cable mod and the dynamat in the cups hoping to god this cures my issue and had a few questions.
1. Id like the cables to be removable so what in your opinion would be the best connections to use 1/4 jacks or Mini XLR's
2. Should I be buying a 4 core cable like this http://www.ebay.co.uk/itm/Van-Damme-Blue-Series-2-Pair-Multicore-/150550560015?pt=UK_Computing_Sound_Vision_Audio_Cables_Adapters&hash=item230d833d0f and wire it to this http://www.ebay.co.uk/itm/3-5mm-Rean-NYS226BG-Straight-Gold-2-Pole-Mono-Tough-Mini-Jack-Connector-/160971310882?pt=UK_Musical_Cables_Leads_Connectors&hash=item257aa34722.
3. as for the earcup wiring as im doing a dual wire mod should I attach the shield to the center pins on both drivers or just the right like was originally wired.
4. also when dismantling my DT's I noticed one of the voice coil strands were touching the middle pin on the side which had all 3 pins soldered, is this bad or does it make no difference.
Please help guys, if none of this works im going to be forced to fork out for new cans and I really hope I dont have too.
Edit:have asked mod to delete the thread I posted in the wrong section.
