Hackasaures
How well do these respond to EQ? I have a pair of HD 6XX’s on the way, and I’d like to round out my lineup with a pair of stronger, more energetic headphones. Possibly by upping the bass and sub-bass on the 5XX
Stay updated on headphones.com at their sponsor profile on Head-Fi.
I was among those skeptical and leaning to the idea that the HE-5XX is likely a re-tuned Deva, and it seems measurements (and some anecdotes posted here) are tilting on that notion (however 'unique' design the product manager said it was).For anyone still wondering if the HE5XX is the Deva, here are some measurements done on the GRAS 43AG:
I also swapped the pads between the two to make sure. The pads are identical, just a different colour:
One thing I do want to note is that this HE5XX I have here (Josh's) has some noticeable channel imbalance going on, so I've just shown the left side here since it's most likely representative. The right side showed some different behavior for both bass and treble - I'll be sure to show both in my full review.
Does this mean that the HE-5XX would have all the pros and cons of the wired Deva?
@crinacle provided FR plots of the Deva and the HE5XX (measured on different rigs) on the day of the HE5XX announcement that pointed to the Deva rather than the HE500 as being the true inspiration. Should have named it the HEDXX
If the HE5XX was announced as a retuned-Deva, I doubt news of that would have raised the hackles of community members.
@Resolve
Do you have 6XX/650/600 measurements on the same rig? I'd be interested in an overlap comparison to 5XX as 5XX is the first Hifiman I've seen tuned like that, looking like Senheiser HD6 series response. It's interesting how it's still spacious with such response.
I think if they cut that peak on the 5-6k, it will sound smoother with vocals.
Your current rig looks reliable, and I'm curous how your's and Crin's compare. It would interesting to see measurements of headphones you both measured to compare any inconsistancies between your rigs.
Wow that looks extremely similar, I thought 5XX would have a much stronger bass and sub-bass, but from the looks of it it's actually even lower.Crin and I are using the same rig. For the most part they should be similar if not the same, but there may be some differences due to A) unit variations/revisions, and B) he uses his on a mobile setup, while mine is fixed on my desk. But in general yeah we compare measurements regularly.... and that's not a euphemism .
As requested, here's the HE6XX. I do also have an HD650 here that's very slightly different in the upper mids/lower treble, but still within tolerances. The HD6XX is so common these days though that it should serve as a solid benchmark. If you're wondering what the target is, it's Harman OE 2013 for bass, and 2018 for mids and treble. So if you prefer the 2018 bass, just imagine the shelf a few dB higher.
Lol, you may be onto something. I guess bad publicity is better than no publicity. In this case, it was a mixed message that engendered 15-20 pages of discussions just a few weeks prior to their release and met (or was close to) their initial sales mark of 500 by 11/6. Not bad for a bit of business.Yes but that's way less fun. Also, "inspired by the legendary HE500" sounds much more appealing than "inspired by the Deva". Maybe this is the long con - we're all talking about it haha.
Likely if your 4XX was the later revision that changed from the 2.5mm over to 3.5mm connectors. I purchased the earlier version of the 4XX before Drop dropped the "Mass" and use a balanced cable from Periapt. I'd be switching over sooner if my balanced 2.5mm cable was compatible. The 5XX appears to be a good value so I'll wait and see if other revisions or improvements come out on the model.Will my other hifiman cables work with these ear cups? I think I have a balanced cable that I not using with the 4xx right now.
So, I did the @takato14 mod, and listening to it now. I really can't tell much of a difference. Bass impact is pretty much the same as before, and I think that is of primary importance if looking for any improvement over the stock character of the 5XX. We need more impact!mod to remove the bass roll of
