boomana
- May 28, 2006
I'm going to try out my FirstWatt F1 and Heed Obelisk integrated (40w) and see what happens.
Originally Posted by kevin gilmore /img/forum/go_quote.gif So the impedance is about 2700 ohms, and the maximum volage is 1000 Vpp? Single ended right??? Should be easy for me to come up with a direct drive amp that does that. Half a BH with the rails at +/-500 and the bias turned up to 15 watts per tube, one tube per channel. |
Originally Posted by boomana /img/forum/go_quote.gif Dew eet! |
Originally Posted by kevin gilmore /img/forum/go_quote.gif 200 volts RMS into 1kohm is 40 watts. While i can do that no sweat, i think that something has to be wrong here. That is 80 watts on your head full blast. No matter how inefficient these things are, And the real heil transducers from 30 years ago were certainly inefficient (i still have one that works) that could work out to almost .5 acoustic watt per side which is way past dangerous. In any case that would work out to a bridged amplifier with + and - 150 volt rails. This is easy. Not going to be cheap however. Something has to be wrong with the impedance number, or that is the minimum impedance at whatever resonance is. Piezo films are usually much higher impedance. Any of the large krell amps could do this kind of voltage swing no problem. |
Originally Posted by Duggeh /img/forum/go_quote.gif The electronics now being disscussed here are beyond the scope of my knowledge but I am excited about the interest from Dr Gilmore. Spritzer I'll be happy to send you the set I have for you to try after they've been to the UK meet, should you be interested. I can understand your opinion on them Re: build and construction. Has anybody opened up the transformer box and checked how it is wired, p-p or SE? That should shed some light on whether the measurements are RMS or not I opened up the case, do the pictures in the review thread shed any light? |
Originally Posted by kevin gilmore /img/forum/go_quote.gif These headphones are only 2 wires per channel. So there is no difference that the headphone see's if the source is balanced bridge or unbalanced. A solid state amplifier in bridge mode is easier to build because of a better selection of lower voltage devices. This is completely different from the stax headphones which are 3 wires and require a balanced bridge drive. |
