AudiophileKing
- Jul 17, 2012
The 'beauty' of capitalism is that it allows any number of scams to exploit others.
It would have been nice if they removed Red and Black and brought out the Cobalt @ 150 USD.
Shillers... Gotta learn to spot them and move on.
OP made an important statement:
"Listen yourself, think it's worth *your* money and then decide if you sound buy them."
I completely agree.
Is the Topping reliable ? I heard they break down and have firmware problems. Can you tell me more about your Topping Unit, it's build quality, software/firmware issues if you are having any.
I've been using the Cobalt for a bit with a few different headphones and honestly... I can't even hear one bit of difference between it and the regular headphone jack in my Macbook Pro. So is it overpriced to me? Yeah, because it doesn't seem to really do anything except provide a cool glow for me to stare at while I listen to some jams.
I’ve had it for a couple weeks and so far so good. I just plug it into my iPhone or iPad mini and it works fine. I use an Apple USB adapter cable which was around $30.
In my opinion, the build quality is good. No complaints so far and hopefully it won’t have any problems
I also didn't think the Cobalt sounded that much better than straight out of my Samsung Galaxy S10. Ended up getting the Fiio Q5s instead and it has substantially better sound quality in all regards.
When I first heard that AQ released the Cobalt as the successor for the Red, I got interested but when I saw the price I lost all interest. A device with one input and one output should not cost that much.
To be fair, mine also wiggles. But it's not the usb plug or headphone jack. Those pieces are actually all one solid internal part. It's just that they snap together into the external case. It's the external case that is slightly loose giving the illusion that the USB plug or jack are wiggling. They aren't though.
Most journalists in the Audiophile Industry are con artists who write about how intense of a fake orgasm they have when they listen to inferior crappy audio products that they receive money to promote.
Ok? What's that got to do with what I said?
