chengbin
- Mar 2, 2009
And please, guys, stay on topic.
-Do your headphones physically react differently between lossless and lossy? High bit rates push more energy (no matter the cans' impedence)
What?
Blind test?
Lossy compression has next to no effect on the amplitude of the analog signal. You aren't going to get physical vibration with one and not the other unless something is seriously wrong somewhere. Even then I have no idea what would be wrong![]()
Your "high bitrate has more energy" thing is really misleading. It makes no sense. More bits doesn't make the analog signal stronger by any means. What exactly did you mean to imply?
Maybe my wording was lazy (I should have said something like REQUIRES more energy, not has more, sorry), but there's no denying that FLAC (for me, 700-1200kbps) takes more energy to play than 320, right? A HD will require more energy to play Song X in FLAC then it would to play Song X in 320, and sometimes I can physically hear the difference between them. Other people have noticed this effect I'm talking about, so I know it isn't some mastering flaw with the music or transducer failure with my cans...
EDIT: I did a blind test comparing Opeth's "Haxprocess" between 320 and FLAC (616kbps) and phyisically, it was very distinguishable (basic SQ, however, not as much but that's obviously a different argument).
Lossy does effect dynamic range which could lead to the perception of more energy in playback.
Could you link me to information on this? Every lossy track I've ripped has had almost identical ReplayGain volume levels to the original lossless, within 0.1dB.
That's because most cds don't really have a dynamic range over 60db or so, so the higher noisefloor of the lossy doesn't come into effect compared to the lossless. However when dealing with something low like 128kbps vs something like 320kbps or lossless, I can tell a difference in the dynamics of percussion in the files. The 320 or lossless file has louder peaks in it compared to the 128kbps version. As regards to the whole visceral aspect though, I have a hard time believing.
