JK1
- Oct 12, 2003
Anyone here do any tests?
I think Jazz is correct that the file size matters. 2 of the same file, with CBR and VBR if they are the same file size should be the same for processing power. If the CBR is a larger file size it might use more battery processing the file
So why not do the test yourself? I'm not going to do it for you.
File size is not the most important factor though. For example, for spoken word podcasts, I use 32 kbps mp3 files on my Sandisk players.While this does give around 10% more run time compared to my 256 kbps music files, this difference seems to be much smaller than the difference in run time between mp3 files and non protected WMA files at the same bit rate. I estimate that WMA files get somewhere between 15% and 20% shorter run time on Sandisk players than mp3 files at the same bitrate.
I am hoping that some people have already done some testing.
No disagreement there. Was simply going on VBR/CBR for MP3. Different formats definitely will have different results
It's going to be device dependent.
