Okay, nobody is declaring that "all amps, dacs and opamps sound the same." That is a fundamental misrepresentation of those people who hold superficially similar beliefs. For example, I do not believe that "all amps sound the same", but all well measuring solid state amps, operated within their limits, do.
To clarify my position on opamps: Modern, well-designed opamps, aimed at audio, implemented in a circuit that takes account of their voltage requirements, impedance and the rest, will sound the same.
That sounds like a lot of caveats, but they are generally met.
I disagree strongly with your statement that such beliefs are unfounded. I gave an earlier example, stating that if two things measure identically as applicable to audibility (for example, a THD reading of 0.0005% is effectively identical to a reading of 0.0001% under this condition), that they should sound the same is firmly established. If someone says they sound different, it is their job to prove that. Asking for null tests is all very well, but not many people have tonnes of measuring equipment lying around. If two things measure the same, why exactly should they not sound the same?
With opamps, for example, it would be even more complex - you can't just shove them all into a CMOY and measure bigger-than-expected differences (for aforementioned reasons).
However, to reinforce this viewpoint I felt it neccessary to have a look at two opamps which supposedly sound considerably different - the OPA627 and the AD8610. Let's compare measurements.
THD+N: This is actually compared in the datasheets (the AD8610 boasting how it outperforms the OPA627 - especially above 20khz). They are both in the region of 0.000x% - totally inaudible.
Noise: Obviously, for opamps this isn't just a signal-to-noise ratio. One is 6nV/(sqrt)Hz, the other is 4.5. Again, this is very low noise - the noise from the rest of the circuit will render this insignificant.
Dynamic Range: Not quite as easy to break down into two numbers, but both opamps are considerably more than fine in this regard.
Slew Rate: 50V/ms vs 55V/ms. Both plenty enough for any audio application I can conceive.
Yes, there are other potentially relevant numbers, but those are the main ones (frequency response isn't even worth worrying about). I double checked this to make sure I wasn't embarassing myself with an article I found from an opamp engineer at Analog Devices. The article is pretty old (1998) but still highly applicable.
[size=xx-small][size=xx-small] [/size][/size]
