If everything else sounds basically the same and just the one amp sounds different, that amp must be doing some sort of processing to deliberately make it sound different. Maybe it's monkeying with the phase. I don't think a headphone amp would incorporate a digital delay, but that would sound very much like what you describe too. In any case, the amp you like is probably the one that isn't performing to spec. If you like it that way, it doesn't matter though.
Have you done direct line level matched A/B comparison? That would probably help you define exactly what the difference is. It would be easier to figure out if your description wasn't so vague. I suspect that the phase/time shifting you're describing doesn't really exist, and some other more common problem is just giving you that impression.
The GS-1 is a straight Kevin Gilmore designed, wire with gain, transistor amp..... and it's been made by the DIY crowd for years in different configurations... Dynalo, Dynahi etc. and I'm pretty sure the schematic is public.
I don't feel like it's doing any processing, it just has more 'resolution' than the others.
I've only compared the HP outs from each of the amps. But I've done it frequently and for years.
Another HFer, Asr, reviewed the GS-1 a few years ago and referred to what I'm trying to describe as "holographic."
It certainly could be described like that, but to me it sounds like it's playing in a larger room than the other amps I have.
Just to say, when a difference is nulled out and recorded in Audacity, the fact you have to turn it up to max volume to hear it - and that is when the difference is isolated into a result track - implies that the difference is probably inaudible under normal usage; but I do find the -45db difference very interesting - it is unfortunate that a more detailed investigation, (investigating the effect of the voltage fed to the opamps for example) will likely never be performed. These are both very high-end opamps - I will PM Ti on his forums to see if I can get more info, he's usually extraordinarily helpful as you well know.
And the Woo3 is a tube amp - we KNOW tube amps have giant measurable differences versus SS, so I find it especially interesting that you declare they sound incredibly similar (Woo and M^3). Assuming the M^3 does not actually measure strangely for a SS amp, which I find very unlikely...hmm, will ask Mr Kan.
However, the Woo3 is a relatively high-end tube amps, and tube amps can still have inaudible levels of distortion and so on when well designed - my immediate reaction is to wonder what the GS-1 is doing to the sound - but speculation isn't particularly fruitful - it could be much higher than advertised crosstalk - crosstalk is rarely perceived in small amounts (well, small in the sense of audible, but not blatantly obviously audible within a second of listening) as a degradation and can have all the effects on the sound stage you spoke of. Faced with a larger subjective soundstage, it can be easier to isolate details - but this is a lot of speculation here. AFAIK the GS-1 has never ended up being measured.
In my experience, I have found the Woo amps not to be very tuby and sound pretty much like good SS amps, so I wasn't surprised not to hear a big difference between the 637/627 M^3 and the Cetron tubed Woo3.
my immediate reaction is to wonder what the GS-1 is doing to the sound .....
It sounds like a clearer version of the same thing played in a larger room. Not an echo or cavernous sound, just like there is more space all around.
Angled drivers are mechanically pointing at a different part of your ear. That isn't possible with an amp. Sound stage is largely created in the mixing of the music, not the equipment reproducing it. But it can be affected by time shifts (reverb) and phase problems (cancellation).
Is the effect consistent across all music, or does it affect some music more than others?
I know......
It's constant across all music and even cable TV and netflix movies.
Just think of it as clearer, better resolution than the M^3 or the Woo3 that is playing in a bigger space. That's the best I can do. Maybe Kevin Gilmore would be able to explain it better.
Another thing, recalling our speaker discussion, is that you might not be able to experience this type of thing with speakers... the increased resolution might be noticeable with headphones only.
