Does anyone prefer lossy over lossless for reasons other than filesize?
Sep 11, 2013 at 5:54 PM Thread Starter Post #1 of 54
dizzyorange
I think I prefer the sound of mp3 over lossless.  I think the difference is very very small but FLAC does seem slighly more open than 320 or V0 mp3.  I did an ABX test and was able to get 100% (but only with careful scrutiny and only by listening to specific parts of songs over and over again, I made a previous post with samples if you want to try).  But the strange thing is I actually like the mp3 better.  It sounds more analog, if you will.  I find I get listening fatigue from listening to lossless that doesn't happen with mp3.  Whether this has to do with the psychoacoustic model or something else I'm not sure.  Anyone else feel the same way?
Sep 11, 2013 at 6:45 PM Post #2 of 54
Perhaps what you are hearing is the added artifacts that compression tends to mix into a track.  I can see how one could interpret those as the pops and clicks of a record, but it is by no means technically more analog.
http://en.wikipedia.org/wiki/Compression_artifact
http://www.soundonsound.com/sos/apr12/articles/lost-in-translation.htm
The fatigue you are hearing is one of the reasons why compression is problematic.  It hides how a track sounds and may make a headphone / speaker sound better than it really is.
I like knowing I have not lost all of the data, but I do fund that 256kbps or better compression is hard to tell from CD with a good DAC.
Sep 11, 2013 at 6:59 PM Post #3 of 54
That's interesting, about compression possibly causing a speaker or headphone to sound better than it really is. I've never thought about it that way, and it kind of makes me rethink things such as lossy or lossless. Very interesting. I think I might have to experiment with this a little.
Sep 11, 2013 at 9:57 PM Post #4 of 54
I wonder if it's because of the sounds below our hearing threshold that are removed by lossy compression.  I think for people who prefer lossless, these sounds may not necessarily always be directly heard, but they can add ambience and depth to the sound.  But I think for me, the "simplification" of the sound that mp3 does makes it easier on the ears.  Less information to process might mean that my brain is not working as hard to decipher the information... just a guess.
That article from soundonsound.com is pretty informative, but I wonder if it's all accurate.  Especially the part about the bass.  I've never noticed any loss of bass on mp3 compression.  Has anyone else noticed this effect?
Sep 11, 2013 at 10:33 PM Post #5 of 54
i think mp3 is grainier and less smooth. no reason to prefer except for file size
Sep 12, 2013 at 7:18 AM Post #6 of 54
No, not really. Besides sound quality, tagging in mp3 really is a mess.
Sep 12, 2013 at 10:46 AM Post #7 of 54
You'd have to compare sound pressure levels between your candidate listening files to know if listener fatigue is involved. This is an interesting source: http://www.livescience.com/14150-earbud-listener-fatigue-solved.html
Sep 12, 2013 at 12:25 PM Post #8 of 54
If you can successfully ABX lossless and lossy encoded at v0 or better then there are three possibilities.
You have made a mistake in your methodology. You have found a 'killer sample'. You are exceptionally gifted,
If you want to know which one applies to you then I suggest you do the following.
Post up your samples here. http://www.hydrogenaudio.org/forums/index.php?showforum=40
Experienced people will try and replicate your results. If they can they will forward the sample to the devs and you will have done everyone a big favour. Either that or they will probably be able to  tell you what you have done wrong. Thereby doing you a favour. If they cannot they will ask you if you can repeat the result using different samples. If you can you will become famous. Not that famous but fairly famous. It's a rare skill.
ed:gmr
Sep 12, 2013 at 5:19 PM Post #9 of 54
ed:gmr
Do they have some samples of this type already (lossless vs. v0 lossy for ABX) posted over there?
Sep 12, 2013 at 6:05 PM Post #11 of 54
Pl
Plenty!
Beware...hydrogen is no place for the underprepared. They are a crusty bunch but the knowledge level is very, very high. I love it for late night reading
I poked around for awhile, but didn't find anything like a standard set or a set in a sticky. There is quite a bit of talk about "killer samples", which is not my interest here. It's great for coders who need samples that are going to reveal deficiencies, if any. I'm looking for hopefully a variety of musical types in both lossless and v0 lossy.
Sep 12, 2013 at 6:05 PM Post #12 of 54
I wouldn't say crusty, just direct and keeping a technical forum technical, that is keeping the BS out.
Sep 12, 2013 at 6:12 PM Post #13 of 54
I would rather just start with their experienced sample sets, rather than posting my own and having to go through a round of review over proper techniques for matching sample pairs properly, and ending up moving on to their own sets anyway as follow-up. Might as well start with something they already consider the most rigorously prepared files.
Sep 12, 2013 at 9:05 PM Post #14 of 54
If you 'feel' the mp3 is better, its your choice. However, the primary need of encoding data (lossy/lossless) is to reduce the file size. Even FLAC is compressed in comparison to CD.
Sep 21, 2013 at 11:24 AM Post #15 of 54
I prefer medium-bitrate MP3s on my Clip+ as they give 13-ish hours of battery runtime rather than 8/9-ish hours. Does that count?
(Admittedly this directly relates to file size, as the difference in battery drain is caused by varying flash memory activity.)
In addition, sometimes low-bitrate lossy files (like whatever AAC you find on 240p Youtube vids these days, 96 kbit?) can "gloss over" things that I didn't want to hear anyway, like high-frequency clipping.
