ciphercomplete
- Feb 21, 2008
Maybe I worded this wrong. The fuzziness is not in the signal as in the 1's and 0's. Interference is picked up by the the actual wire and it travels that wire to the next component, the DAC. I never said it effects the signal but it can cause noise (what I should have said instead of fuzziness) on the analog side simply because of this nearby added interference. I look at any interconnect as a potential antenna for noise so you have to make sure they are properly shielded. I just look at optical as another way to reduce noise. It isolates the DAC from the transport by eliminating any electrical signals. The difference I heard from using a optical cable instead of a coax was a further elimination of noise. I don't for one second think that optical "sounds" better than coax under ideal noiseless conditons. 1's and 0's are the same no matter the signal.
Originally Posted by m1abrams /img/forum/go_quote.gif Since when do you get fuzziness interference in a digital signal? And the reason people poo poo optical is because of the belief that optical introduces jitter more than coax due to the way optical must be converted from electrical to optical then back to electrical. I can not determine a lick of difference myself when using my gamma2 with my Squeezebox switching between optical and coax. But really fuzziness in a digital signal? |
