do you need headphones plugged into an amp while burning it in?
post-189720
Post #2 of 17
Czilla9000
10 Year Member. Still no custom title.
Well I assume it needs to plugged in some amp (whether it be from a portable or receiver or otherwise) inorder to produce any music at all.
post-189722
Post #3 of 17
SumB
Any line level signal will suffice.
post-189723
Post #4 of 17
poorimpulsectrl
Whups, I guess I should have been more specific. It's the amp that I'm burning in, not the headphones. So to burn in the amp, do I need headphones plugged in? I assume yes, given that it's the driving of the headphones that one aims to improve with burn in.
post-189724
Post #5 of 17
poorimpulsectrl
I'm sorry, I don't follow. That means so long as music is coming into the input on the amp it's going to get burned in?
post-189736
Post #6 of 17
SumB
Sorry, I thought the question was directed at headphones. For the amplifier it shouldn't matter as long as a signal is passing through, although presenting it with some sort of load can't hurt.
post-189737
Post #7 of 17
poorimpulsectrl
Great, thank you SumB. I think I'll opt to let the amp run overnight without any headphones plugged into it.
post-189748
Post #8 of 17
lini
Thought the last line in Citizen Kane was nosebud.
poorimpulsectrl: If you don't want just the gain stages to burn in, you should connect a headphone. Otherwise it would be similar to running a car in by just leaving the engine on but not driving one metre...
Greetings from Munich!
Manfred / lini
post-189770
Post #9 of 17
SumB
The output stage is active whether a load is presented or not. In fact with most solid state devices lowering the load resistance will result in higher power.
post-189804
Post #10 of 17
LTUCCI1924
HI: I don't know the answer to that question but at the present time I am burning in a Max-Out META42 for 2 days straight and have a pair of headphones plug in to them. Why, I think that its good to have a release for the music from the amp and its also is fun to through on the cans when ever I get near them. This way I can monitor what the burn in is doing. Its been about 17 hours so far and when I work up and put on the cans that were running all nite I have a lot louder sound than before I went to bed and the lows and mids and highs are opening up much more. Now they will burn all day and all nite till 3 O'Clock tomorrow. I think that 48 hours will be enough for the burn in then just get down.
post-189860
Post #11 of 17
KurtW
The output stage is active with no headphones plugged in, but its loafing along outputing no power, with less than normal amount of heat on the output devices. The best burn in would be with headphones, particularly ones that are hard to drive if you have a choice. I usually use a FM tuner for a source so I don't needlessly wear out a CD player.
post-190261
Post #12 of 17
Dusty Chalk
Head-Fi-holic: With headphones would just be a benny.
Short answer: yes, that is the best way.
post-190366
Post #13 of 17
Budgie
Never looks a gift amp in the jackhole.
Yes, plug the phones in. Use some cheap phones if you don't want to leave your good ones running that long.
post-190446
Post #14 of 17
Aboogwa
Originally posted by poorimpulsectrl
see subject line for stupid newbie question.
thanks
Just out of curiosity, what amp is this?
And how do you like it?
post-214649
Post #15 of 17
SumB
Cary is one example of a manufacturer that burns in its amplifiers without a load or signal present.
