NotJeffBuckley
- Dec 17, 2005
Run a CRC verification and you'll have your answer as to whether the copy is perfect or not. Bits are bits, and there's no point adopting some sort of strange holistic viewpoint of the process. Compound degradations also don't come into play unless you're copying copies for many, many, many generations, and if each successive copy is successful (has no CRC errors when recompiled) then the successive copies from that one will be, too.
CRC every copy for 24, or any other arbitrary number of copies, and if each matches the original you've had no degradation.
Edit: And, yes, I ABX and DBT. It's the only way to remove the observation variables and get a true analysis. It's letting your ears tell you the truth without interference from your eyes and the expectations that come with expense.
