SP Wild
- Dec 29, 2009
IME, IMHO etc...........
Thats all the knowledge I have in regards to USB - I can't answer your questions specifically - it's beyond my technical understanding. Its all voodoo as far as I know!
To put it in perspective, I paid AUS$3200 for my Bryston BDA-1 dac. Its USB input - rubbish!
Then please don't comment on things you don't understand.
Right. Measurements with an RME soundcard showed that jitter dropped from 456 to just 98ps using USB instead of TosLink. So what the .. are you talking about?
@plonter: Don't worry too much..
Originally Posted by SP Wild /img/forum/go_quote.gif
Are you suggesting Plonter carry out a DBT to prove what he heard was real?
Can you provide a link to the Bryston USB input jitter measurements?
plonter, the most simple explanation would be that the decoded audio will be passed to the streaming subsystem (which runs in kernel mode, that means it has higher priority than normal processes) of Windows, which will then send the audio data in 1ms chunks over usb to the usb receiver in your dac. The receiver will buffer that chunk and pass it on to D/A conversion.
i still don't fully understand something,i would like you guys to explain it to me like i am a 6 years old.
if the "onboard" sound card is actually a part of the motherboard...and the usb output of the computer is also coming from the motherboard,than what is the difference between the two? (is there any difference at all?)
i mean..if i can get the on board spdif out to work with wasapi,shouldn't it be the same like using wasapi with usb?
I can reject via that usb to dac at low sampling rate does not sound different than toslink at high sampling rate.
