joir
- Sep 1, 2008
Build or buy?
If you like to make/build your own things then build, if not then buy. Its that simple!
If you like building then it will give you pleasure while building it and continue after its complete.
For me listening to something I made is very satisfying, it is so important that I can not see any commercial design competing
And in regard to tools then you need a decent soldering iron, solder, solder braid or desoldering pump(correct word?), good cutters and a basic multimeter. These are the tools that you must have, anything alse is nice to have. Of course these tools will not be enough for casing the amp.
I don't know how familiar to electronics you are but I would suggest something rather simple (cmoy?) and well documented to start with and use it for learning to read schematics and figure out how it works. Fault finding can be a daunting task, even when you read schematics and know how the circuit works
Regards, Jói
Regards, Jói
