bigshot
Everyone is subject to expectation bias. Even sound engineers (and producers!). We all have bias and we all have perceptual error. The tool for negating it is simple... a blind, level matched, direct A/B switched comparison. I've done more of these than I can count. The burden of proof is on you to prove a difference if one exists. Don't just guess and tell me what you think. Take a little initiative and check yourself to see if your impression is correct or colored by bias and error. I know what the odds are. I am fairly confident which side of that you fall on.
You are in Sound Science. Here we get to tell you that you need a controlled test if you want us to believe you. Until you get off your butt and start thinking critically, I get to tell you that you most likely have no clue what you are talking about.
