bigshot
No one ever went broke underestimating the intelligence of the public.
Very true, but what if they asked you if their Kia soul would run better or be faster with Turbo Blue 110 octane racing fuel or some fancy tripple tipped spark plug. Or should they get that cool looking electric turbo off ebay because the add says it adds 10- 20 horsepower. Or some plug in performance computer chip that does absolutely nothing. Or should my 15 year old daughter with a 25 inch draw length and 45 lbs of draw weight use a 350 grain arrow with a mechanical hunting tip because it will be faster, flatter and easier to tune. Those are things I can answer and tell you exactly why it either won't work or is a horrible idea.You don’t have to be an auto mechanic to tell someone they can’t run their car on water instead of gasoline.
All thouse switches and routers are in the realm of networking: binary signalling at physical layer; framing at data link layer; packet routing at network layer; and message transport at 3-way handshake TCP protocol at transport layer. No streaming DACs in these network segments. Which brings us to the last mile integration: delivery to the audiophile network. All of sudden, we care about LF/HF noise. Previously, we didn't care but now we care. And here we have two schools of thought.If I’m streaming music music, say from Tidal, those 1’s and 0’s have been through an untold amount of hubs, switches, routers, the local exchange, and long lengths of copper cable. I’m assuming that all this equipment would have been designed to carry data, and therefore not of‘audiophile‘ quality.
Are people saying that none of this matters, as long as you use an ‘audiophile’ network switch in your home?
Most of it all sounded the same. In a few cases the tidal versions sounded a bit better. And in a few cases the CD's sounded better.
Incorrect. Ethernet cables are tested to between 250ft and 300ft for data integrity.So this is another angle to look at the alleged problem. This is concerning USB cables going directly to the DAC, not ethernet cables usually going directly to a source device, but in either case, we're talking about the proposed effects of interference on a digital cable. Ironically, I found this link because someone on reddit was trying to use it to defend the practice of buying an expensive USB cable, but I digress.
https://www.audiosciencereview.com/...s/do-usb-audio-cables-make-a-difference.1887/
The conclusion was that Amir actually did find a measurable difference between USB cables when using the worst-performing DAC he'd measured at that point. However, the measured difference was far below human hearing and this is a worst-case scenario, as the Schiit Modi DAC he used was doing a poor job of filtering noise on the data and power inputs.
So worst-case scenario on a DAC doing a poor filtering job...the difference was measurable but not audible.
I believe with a good degree of confidence that the conclusion could be extrapolated to ethernet cables.
No you are just making crap up. You are taking one limited test between a dac and a source and trying to apply that same measurements to streaming music via ethernet cable. It's completely ludicrous. First the other test proved it was below audible detection. Second data transfer rate of the different systems is completely different. Plus the data still has to be processed by the pc and the dac as well as the drivers.I was speaking purely about the theory that interference running along the ethernet cables is affecting the sound. It's a ridiculous argument, to be sure, but just pointing out that a DAC that was bad at filtering out interference did show noise on a measurement - but that noise was well below the range of human hearing.
