Paul Mohr
In my opinion in the digital realm things either work or they don't. The easiest way for me explain it is with video. A fancy HDMI cable is not going to make the picture on your tv better. It won't have better contrast or more vibrant colors. If the cable doesn't work or doesn't carry enough data you simply don't get an image. Or that image is so messed up it isn't watchable. The same would be true of audio. You either don't get a signal which means no sound or get some kind screwed up sound that isn't even music. It just ends up being some kind of noisy mess. Most of us have heard that sound, its just noise. Over the air digital tv or satellite works the same way. You either get a perfect picture, no picture or a picture that freezes. You don't get less video quality, a fuzzy picture or ghosting.
I will say I find it amusing how the categories on the forum are grouped. One category above this one is the polar opposite. If you posted this topic in the section above this one you would completely different responses. People would be raving about the sound they get with their expensive switcher, router, eithernet cables and 300 dollar power cords.
Unless you are trying to solve a problem that already exists like stuttering, buffering, hum or static I don't see a point in any of this stuff. The amount of stuff video and audio runs through both digital and analog before it gets to your ears or eyes is mind boggling. I don't think changing one component in that chain like a cable or something is going to make any difference. To me this seems no different than someone running 10 ga speaker wire to a speaker that is 3 feet away drawing 20 watts of power. Then saying they can hear a difference. No you didn't, unless your previous wire was messed up or had a poor connection. The wiring in your amp or speaker is probably 18 ga, if that good. I saw this a lot in car audio. Guys would run speaker wire that was as large or larger than the wire they had running to the amp lol. And the sub woofer was like a foot or two away from the amp.
