cifani090
- Jan 31, 2010
I was right
The clip that correct (not giving it away) has a bit more power in the voice.
I was rightThe clip that correct (not giving it away) has a bit more power in the voice.
Now try the test at mp3ornot.com
It's similar (128 vs 320) but the idea is to blind test 3 tracks multiple times, and then get a %. 15-20 times would give you something that is statistically significant.
This one is a lot harder than the original test from this thread, and just shows how far lossy compression has come in the last few years. It seems to be more easily detected with gear higher up the chain (more revealing). Interesting exercise anyway.
Ya, thats definitely harder.
copy/paste score
I chose correctly.
The immediate 'obvious' difference to me was that the 'z' of the 'cos' 320 kbps mp3 was slightly raspier than the 128 kbps version.
Hearing the difference between different bitrate mp3s may be be more immediate when comparing acoustic jazz mp3s instead of recordings with a distorted sound such as the ones in the above test.
Try a minimum of 15-20 cycles. Should give a really good guide. By trial and error (and doing it enough times), anyone can get a 4/4 - even by guessing. Far harder to achieve 15/15 or 20/20. And yes - it's supposed to repeat, and there are only 3 tracks.
Mine was
thats impressive! I went ahead from my previous and got to 6/13, and then decided to stop, for my own good.
what equipment where you using?
