h4n9m4n
- Sep 17, 2005
hi, im new. I love doing DIY-things, but i dont really do them often, so i need to learn a lot. So far i've only been doing DIY things with minimal case modding or wire splicing and stuff. I want to move up to soldering stuff, and working with circuits or whatever. I plan to make one of them cmoy thingys. i know theres already bunches of threads out there, but the problem i have is that i only have one source for parts. Radioshack. im only 14, so of course i dont have a credit card. my parents dont let me buy stuff online anyway. okay. If someone is kind enough to help, please do.
The tangent tutorial's part list is a little complicated and im not sure what to buy, but i think i figured it out.
This is what i plan to buy: (give me recommendations plz)
iron:
http://www.radioshack.com/product.as...84&site=search
solder:
http://www.radioshack.com/product.as...%5Fid=64%2D013
desolder vacuum:
http://www.radioshack.com/product.as...98&site=search
hookup wires:
http://www.radioshack.com/product.as...%5Fid=278-1221
i already have cutters, multimeter, wire stippers, screwdrivers.
now for the amp.
2 of these capacitor thingys
http://www.radioshack.com/product.as...29&site=search
one of these cap thingys (its a 2 pack)
http://www.radioshack.com/product.as...69&site=search
a pack of these(resistors):
http://www.radioshack.com/product.as...t%5Fid=271-309
Found 3 op-amps at radioshack.
http://www.radioshack.com/product.as...t%5Fid=276-007
http://www.radioshack.com/product.as...%5Fid=276-1715
http://www.radioshack.com/product.as...%5Fid=276-1731
the LM741CN looks good (description sounded good), but since its the cheapest of all three, i dont know.
3mm LED (does it have to be 3mm? blue only comes in 5mm...)
http://www.radioshack.com/product.as...t%5Fid=276-026
2 of these jacks:
http://www.radioshack.com/product.as...46&site=search
can i substitute a jack for a cable? if i can, i could probably just have a male 1/8 plug coming out of my amp, so i can just have the amplifier right next to my music player. i might even be able to make a retractable cord...
a protoboard
http://www.radioshack.com/product.as...50&site=search
spst toggle switch
http://www.radioshack.com/product.as...24&site=search
volume knob
9v connectors:
some alligator clips:
http://www.radioshack.com/product.as...%5Fid=278-1156
i can use as many 9v batterys i want as long as i have enough connectors, right?
thats all i need to know... for now. i hope the tutorial will guide me through.
i hope radioshack's parts will let me at least use this for 6 months. then i might try for a PiMETA
thanks in advance.
One more thing, i have a pair of sony srs-p7 speakers that i got for 10 dollars. They are passive speakers, so they are unamplified. do you think i can put a cmoy in one of them and have it amplify both speakers? or will i have to change the wiring?
iron:
solder:
desolder vacuum:
hookup wires:
now for the amp.
2 of these jacks:
a protoboard
spst toggle switch
volume knob
9v connectors:
thanks in advance.
