johan851
- Dec 26, 2005
Hey all. I just finished building an M3 that I was planning to use both as a headphone amp and as a preamp. I also have a Pioneer A35R that supposedly has a power amp mode (allowing you to plug in a preamp and bypass the internal one) and now that I try it, it's apparent that the internal preamp isn't bypassed. I might as well get a power amp, if that's the case.
I've googled around a little bit, and seems like there are a lot of power amp kits out there. I have no idea where to start. I know that I'd like something that's class AB or class D, and I probably want around 20w or so (more is ok). Does anyone have any suggestions? I'd like to keep my budget realistic...probably in the $300 range or so. If anyone thinks I would be better off just buying something like a Rotel RB-1050, I could do that too.
