error401
- Oct 11, 2006
I too would choose WM8740. It uses about 24mA at 3.3V, which isn't too bad if you're using AA cells (typically 2500mAh+), whatever amp topology you choose, it will likely use a lot more. Choose opamps carefully and you should get good battery life (I'd guess about 16h is possible).
It's probably possible to fit a WM8740 DAC and (SMD) opamp-based amp into the smallest Hammond with two AAs, if you're very careful with your layout. I don't think you'd manage cramming a charger in there too though. If you choose a larger case, it should be easy.
Be warned that I might get bored and do a layout for you
Originally Posted by joneeboi /img/forum/go_quote.gif Now, I'm not a design expert of any kind just yet, but perhaps we can design our own portable, full on DAC/amp solution using some of Wolfson's better DACs. I realize there are already solutions available along these lines, but none fitting the I2S input requirement. stevenkelby, you mentioned using the Headamp Pico for its I2S input, but that DAC/amp converts USB to I2s. Unless we open it up and route some wires, we can't do it without voiding the warranty. I'm not sure how we'd go about doing this, but is it a viable solution having a portable DAC/amp running off a 9V? That's quite a huge energy loss converting down to 3.3V, so maybe running off some AAs would be wiser. Before we even go there, we should probably pick out a DAC that'll work. I'm thinking something along the lines of a portable full-on DAC, like a portable TPA Opus DAC (okay, maybe not that far). I'm looking at some Wolfson DACs over at Mouser, and a couple of the models jump out immediately. They all seem to be designed for DVD players or digital set-top boxes, but if somehow we can plow through with the design, I think the head-fi community would be better for it. I'm no Alf, cetoole, Jambo, justin w., Ray Samuels, etc., but I can offer my limited knowledge and unbridled passion and enthusiasm to this kind of project. Please, someone with actual knowledge help me out here. ![]() Some of the DACs that I think would work here. http://www.wolfsonmicro.com/uploads/.../en/WM8761.pdf http://www.wolfsonmicro.com/uploads/.../en/WM8521.pdf http://www.wolfsonmicro.com/uploads/.../en/WM8956.pdf http://www.wolfsonmicro.com/uploads/...728_Rev4.4.pdf http://www.wolfsonmicro.com/uploads/.../en/WM8761.pdf |
