Mooses9
- Feb 12, 2009
you guys have some sexy cables for sure
Finally took the initiative to re-do this cable. Honestly the soldering job was like crap back then and I consider this the most difficult wire to make an IEM cable with due to the extreme number of litzed wires per wire (like 516). It's insanely difficult to form the right shape to fit the soldering joints inside the plugs, and then the skin is so soft and doesn't take much heat, it can just be a nightmare to tin the wire for soldering. Also it's really difficult to insulate.
Hakugei Gaea
any taobao links for the wire that u mention? since my chinese proficient sucks can't search properlyHere:
https://drop.com/buy/cardas-premium-clear-light-headphone-cables?defaultSelectionIds=968110
Edit: but you can get cardas gold reference on taobao now actaully. Cheaper and likely better than the Cardas Clear Light.
Here:any taobao links for the wire that u mention? since my chinese proficient sucks can't search properly
thanks again.
Ok it's not too bad and the key is to keep the splitter-earhook end long, like 60cm.
Just received this and it's a thick 2mm silver plated copper and copper wire (or alloy),...ok good thing is measured the resistance it's under 0.2ohm per 5m...and bad thing is it's quite stiff, not pliable at all. The plating is of very high quality and very conductive thou. I wonder if I can make a cable with it already. (And resistance is not directly related to sound quality btw, just measured for information).
It's finally done.Ok it's not too bad and the key is to keep the splitter-earhook end long, like 60cm.
Not yet terminated.
It depends on which Hakugei cable I guess. The Furutech plug is best to pair with silver plated or silver wires from my experiments so if it isn't then it might become a bit too smooth.Hye love reading your DIY journey thread....
I need some advice.... I recently bought a hakugei cable from their AE store,
1) Im not sure if it's a real pentaconn plug (could be fake tho)
2) they're using mudolf supreme..
The issue I had with the cable is,
1) it is lacking reverb..
2) mid-range/vocals abit lacks forwardness body,dry and soulless, strings just dont have the reverb or echo on hits.
3) treble had this lean yet hazy sound.
4) But the stage is wide, quite fast in transient only that it lacks dynamic and timbre lacking realism.
I am considering furutech FT-7445 plug but the last time I tried using this on my CEMA, the sound become too smooth in detail and dull in dynamics..
I have a guy who can do the welding but I need some advice as to which plug and solder to replace...
Ah I see...It depends on which Hakugei cable I guess. The Furutech plug is best to pair with silver plated or silver wires from my experiments so if it isn't then it might become a bit too smooth.
If you want timbre realism, I mean absolutely best timbre you should try Bispa gold plated but they are closing down unfortunately although you can still get from their webshop under their current hungry marketing.
Btw, Hakugei do not use Pentaconn plugs as they are quite costly anyway and they use Mundorf silvergold not superme as I asked them once.
