Bow to Ed
- Dec 30, 2011
Hi all,
I have looked into doing this with shredded CAT5 cable. I have, however, made an audio interconnect that's about 9" long terminated in two 3.5mm connectors. It picks up an annoying level of noise especially when I place my hand next to it. Still, that's a low-level signal wire sitting on a high-impedance input (1M resistor to ground and into the input of an op amp). I tried doing this mod with a pair of no-name headphones but ended up destroying the drivers with an over-zealous soldering iron.
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_173164_-1
Recently I re-cabled my Skullcandy GI headphones [1]. I used the wire listed in the above link, which is tin plated copper with PVC insulation, 100 feet for $10. When I made the wires, I placed the raw wire in a drill and tightened it to about 6 or 8 turns per inch. I haven't measured resistance or capacitance per foot here. This wire is not liquid-flexible but it is more so than the solid CAT5 UTP. Since it's a headphone cable (located in a low-impedance section of the amplifier) then the noise pickup is non-existent. I would highly recommend this wire for a re-cabling, especially if you are confident in your soldering skills or aren't afraid of ruining your cans. I hear more details in the audio than I did when the headphones used the multi-stranded magnet wire and I like the low frequency response I hear now. Maybe it's real and maybe not.
Also, if you're trying to experiment with speaker cables, you could make flat cable using eight lengths of UTP. This 24 AWG wire has 0.205 square mm of cross-section area. With 16 AWG having an area of 1.31 square mm, eight pairs of wire overshoots that slightly, and can be laid flat, clamped every four to six inches with a plastic or wood clamp.
I'm not claiming to be a transmission line expert or a master of audio engineering. I've tried something, it worked for me, I'm reporting my findings so someone else can give it a shot. Yes, I know that lengths of CAT5 cable can often be found for free in the trash.
Ed
Ed
