It can be tricky with UK wiring,as it's all in close proximity, but by following cdacosta method, and using small amounts, it can work wonders.
l know l mentioned it, but adding a low noise psu,will transform your router or switch. And without going on a completely different tangent, you should consider going to FMC, pretty cheap to do so, and a worthwhile upgrade in my view.
lf it helps, l started with RC at my electric breaker board, by adding 14grams in front on the trip switches, the reality is our houses are full of noise.
