Ok, so my graphite sheet ground box 'cloaking' experiment was a home run in terms of it exceeding my expectations in improving the sound. The below test was on a single Quartz Acoustic box connected to a spare analogue RCA input on my active speakers/second system. Cable was 6N as pictured + CDA wrap.
The typical improvements of higher quality signal grounding (more expansive and better defined soundstage, more palpable and textured vocals with less edginess/glare, greater bass weight and definition and a greater flow) were present and progressive:
- graphite sheets were better than no sheets/bare ground box walls
- thicker 1mm sheets better than 0.5mm (the 1mm was more balanced, much more palpable vocals)
- the more surfaces that were covered the better 5 > 4 > 2.
I was able to easily AB the above just adding and removing sheets of different thicknesses. Quick and easy to AB, easy to hear the delta.
Once I covered the last, fifth, wall with a final 1mm sheet I went wow, it was like everything snapped into place - such a full, rich, dynamic, resolving and expansive sound. Oh yeah.
I bought two thickness of graphite 'sheet' from Alix, 0.5mm and 1mm thick. See the photos of the 4 sheets from above and the two packs for an idea or relative thicknesses. The 1mm feels thicker than 1mm.
It's supposed to be flexible like the product photo but in reality it feels like stiff cardboard but is more inflexible and quite brittle, you permanently sharply crease (partly tear) it with a small amount of force or flex (such as around the corner of a ground box), and with just one further flex in the opposite directions it breaks completely off with small pieces of what seem to be layers of graphite fibre becoming apparent around the tear. The fibres are relatively soft, not at all like carbon fibre.
https://a.aliexpress.com/_mtISIqU
Excuse the rough tears etc and overhangs this was just a rough first test, proof of concept.
