silver cables ( not silver plated) . $25 -1/2 m connected to the boxes with banaplugs. Streamer,routers and modem connected by USB. RCA to dac and alligator clip to switch. Have a $55 AWG14 silver rca for the dac on order. Hope i don't hear a difference. Will save me money.
The amp has a pass through output. Tried both neg and pos with a "rca-cap" soldered to the cable. Probably not ideal. They sell cables with 3,5mm jack. Have to use a 3,5/6,3mm adapter though.
The small boxes are without any inside copper plating, but the two larger ones are copper plated.
I tried the different boxes with a Chord Qutest in my main system. Rca with BNC adapter and USB inputs. No improvement in SQ to my ears.
The benefits i can hear using the boxes in my bedroom system are a better sence of depth and imageing as well as removal of glear and harshness in "hot" recordings. Seems to help "drain" HF noise from components.
In my system the wireless Asus routers benefits the most from connecting a grounding box.
EDIT: The first small box i bought with the cheap silver plated cable. The second one with the upgrade silver. The copper silver plated is clearly inferior to the silver. Not recomended imo.
It is cool to hear from others that have tried any ground boxes. With a well designed ground box (which includes cable) should improve the Chord Qutest, so this is interesting. I do recommend cable rolling. I have found that the cable (wire and connections) and how/where the device is installed make 50% or so of the performance of the device. So far I have found the following wire to sonically be the best:
* 12ga or larger diameter high grade copper, stranded (finer the strand the better), mixed diameter stranded even better
* Thin gauge wire are not as effective as 12ga. to 10ga. Also the thinner wire usually sound imbalanced across the frequency spectrum.
* I have had mixed results with 4N silver and silver 5N Cardas. In different diameters (from 32ga to 22ga) mixed to get a larger gauge. Tonally imbalanced. But might work well mixed with copper, have not tried that yet. May also perform better if pre-cooked on a cable cooker, not tried that yet either.
* Stranded outperforms solid core
* Silver plated copper sounds horrible in my system. Especially those $6 - $10 Aliexpress cables or the by the foot silver plated cables that are listed as higher grade on Aliexpress. I tried a few and did not like any of them.
* Solderless connections outperform soldered connections
So far the best performing wire for the money I have found is the copper 2.0 sized ( which is 14ga.) dual twisted, giving an 11AWG. 1m to 1.6m in cable length. Sonically has outperformed everything I have tried so far, which is about 20 different wire from different brands. Very balanced, superb performance overall and inexpensive. I buy it here:
https://www.aliexpress.us/item/2255...st_main.5.726a1802V5yIOt&gatewayAdapt=glo2usa
