Oct 11, 2024 at 5:08 AM Post #2,371 of 2,979
YTERAUDIO Store:
"I don't have 49 cores so please apply to cancel the order"
Oct 11, 2024 at 5:16 AM Post #2,372 of 2,979
YTERAUDIO Store:
The pictures in the listing shows 7 bundles of 7 cores per bundle. You may want to ask the seller if the cable they are selling looks like the ones in the pictures in the listing? Sometimes their English is not that good.
Oct 11, 2024 at 6:27 AM Post #2,373 of 2,979
Unfortunately, the conversation was not to be misunderstood.
But - the previously tested OCC wire diameters are 0.2mm and 0.37mm at 2mm², with the finer one being more high-resolution. However, all possible diameters are still available in 19-strand bundles: 0.183mm at 0.5mm², 0.224mm at 0.75mm², 0.259mm at 1mm², and 0.317mm at 1.5mm². And the possibility of mixing them makes me excitedly nervous... let's say.
Oct 11, 2024 at 1:14 PM Post #2,374 of 2,979
Just be aware that the burn-in without a cable cooker could be quite long because of the amount of Teflon dielectric with such a cable build.
Oct 11, 2024 at 6:33 PM Post #2,375 of 2,979
I have never seen this wire with 19 solid core. But I think you are correct about the 7 bundles of 7 core per bundle. Oops, just checked the actual wire. The recent order I received was for 10m of 2.0mm (14ga.) and it appears to be the 7 bundles of 7 core per bundle.
Dam I just checked the wire that just arrived and it seems to be not the 49 strand ones. Its just straight wire. That said, I did a quick count and it was like 30 cores. So maybe i got something else after all. The photos, looking back now, is saying i bought the 19 strand version. But that's not what I got.
I wonder if we could just buy the smaller gauge ones and run multiple twisted cores to mimic the quantity/thickness of the previous 49 cores?
Oct 12, 2024 at 2:07 AM Post #2,376 of 2,979
Have been experimenting with the Oyaide NRF-005T for about 2.5 hours. I do not have time tonight to get into detail what I learned so far. I will report in a couple of days. I will say I like this Oyaide noise reduction tape. I also have the MWA series which is a EMI reduction tape, what the NRF-005T does is very different. Most importantly is that it does not effect tonal balance or have any negatives that I can detect so far. Not much info or reviews on this material either which is a bit surprising. Not that expensive either. With expedited shipping via FedEx was $83.73 all in. Ordered 10/8 and got it today 10/11 from Japan, surprisingly fast. This tape is 15mm wide by 4 meters long.
Here is where I purchased the NRF-005T:
https://www.ebay.com/itm/256642357380
After ordering the tape I received a message from the seller asking if I had any questions? Or if I would like to expedite the shipping for an extra cost? The expedited shipping was $10. Otherwise for $73.73 would take up to 30 days for economy shipping. Smooth and easy transaction. More to come...
Oct 12, 2024 at 6:32 AM Post #2,377 of 2,979
Appreciate the report, this has been in my watch list in a post fo.Q world.
Oct 12, 2024 at 10:40 AM Post #2,378 of 2,979
thanks, really thinking of trying it out
i just tested some copper tape on the dac chip of my interface, the difference is quite huge, which was kinda surprising so im now even more curious... :)
i just wonder whether there are more alternatives, i remember like some EMI filtering "sheets"
Oct 12, 2024 at 10:53 AM Post #2,379 of 2,979
i also have a (partial) report:
my 3d printing primer cubes arrived, i paid in the end 55,98 euro for 10 pieces at 50,5% scale, they were cheaper because they came with slight errors from the 3d printer
i probably will use a few for myself, but if one is interested in one hit me up its 6 euro per piece + shipping from germany (you need to source and glue the magnets yourself, you need 5x5x5mm cube ones)
im half done now building one (3 out of 5 rows filled with magnets, waiting for the glue to dry) and the effect is already pretty audible... probably the best standalone tweak i tried since some time but i will do some more listening, tho first impression is it sounds alot "smoother/more natural" than previous neodym tweaks and it also comes with this "immersive" property, speakers literally scaled up in size... :)
Oct 12, 2024 at 12:45 PM Post #2,380 of 2,979
ich habe auch einen (Teil-)Bericht:
meine 3D-Druck-Primer-Würfel sind angekommen, ich habe am Ende 55,98 Euro für 10 Stück im Maßstab 50,5 % bezahlt, sie waren billiger, weil sie mit leichten Fehlern aus dem 3D-Drucker kamen
ich werde wahrscheinlich ein paar für mich selbst verwenden, aber wenn jemand an einem interessiert ist, melden Sie sich bei mir. Es kostet 6 Euro pro Stück + Versand aus Deutschland (Sie müssen die Magnete selbst besorgen und ankleben, Sie benötigen 5 x 5 x 5 mm große Würfel).
ich bin jetzt mit dem Bau eines halb fertig (3 von 5 Reihen mit Magneten gefüllt, warte darauf, dass der Kleber trocknet) und der Effekt ist schon gut hörbar... wahrscheinlich der beste Standalone-Tweak, den ich seit einiger Zeit ausprobiert habe, aber ich werde noch ein bisschen zuhören, obwohl mein erster Eindruck ist, dass es viel „sanfter/natürlicher“ klingt als vorherige Neodym-Tweaks und es verfügt außerdem über diese „immersive“ Eigenschaft, Lautsprecher, die buchstäblich in der Größe skaliert sind...:)
`Pictures ?
Oct 12, 2024 at 12:48 PM Post #2,381 of 2,979
GhoostKnight I definitely want to try these, how many do you recommend? If you're willing to ship to Canada I'm in!
Oct 12, 2024 at 1:25 PM Post #2,382 of 2,979
my first version looks a bit messy, best is to use superglue and you might get it together somewhat clean (tho, the more magnets are in the harder it gets to place new ones)
you also see the print errors on the left on the back, its a bit rougher texture, nothing major
the "top" (bowl) side is nicely printed
well i have only tested one so far, imo the effect is already quite noticable, just like other magnet tweaks, but i will definitely test 1 per side (currently i placed it on one of my grounding boxes)
just hit me a PM i will look up shipping cost
there are some sources if you wanna know more about the "primer cube", tho i havent dived deep myself, it was a new esoteric thing to test and i was still curious about magnetism, so here we are x)
Oct 12, 2024 at 2:13 PM Post #2,383 of 2,979
Is that a new product?
Oct 12, 2024 at 2:21 PM Post #2,384 of 2,979
I thought it was originally you that mentioned this just came out about 1.5 years or so ago. This material is very interesting. I need more time experimenting with it to be able to properly opine on it. I like what it does and is very different than the Oyaide MWA EMI tape.
Oct 12, 2024 at 2:25 PM Post #2,385 of 2,979
Interested to hear your impressions on that tape.
