captione
@furyossa
The Bery is the black one.
I will double-check the cover placement.
By the way, should I glue the shells?
Two dabs of glue on the back lip of the shell will do. Don't need alot when you plan to fix it. Just make sure it doesn't stick to the drivers too much, only the faceplate lips.
Make sure you don't forget something you need done when gluing in place, like putting additional damping, tuning foam, etc...
