JDFlood
I have never been able to tell much of anything at a vendors location. Everything is foreign, too many choices, very distracting environment. Much of the difficulty has to do with the complex nature of music. You are not comparing one tone between different headphones... or systems... it is dozens constantly changing. Take one single drum beat: there is a leading edge, sweep through frequencies, heft, decay, etc... all of which will be somewhat different among what you listened to. Your mind must really make a holistic appraisal while your mind’s eye (ear) flits from transient sound to sound. so first it takes experience learning to observe the different components of the sound of music reproduction... and the language. Tonal balance, rhythm and pace, leading edges, slam...etc. if you are interested, there is a great deal of pleasure to be derived from pursuing better sound in music. It can be overwhelming At the start. I think getting a high quality set of headphones and DAC/Amp is a good way to go. Then enjoy the music at that plateau, and you will learn to appreciate them, and maybe realize you would like a higher quality sound. You may like certain aspects of the sound more than others. Typically at first slam and bass is what is desired, but your priorities may change over time. The sound you get is the result of the whole system, source, headphones, amp, DAC, interconnects. Most of us use a separate DAC and amp for more flexibility in upgrade, but there are many really good high quality integrated components.
LCD-2 are great headphones, very capable of tremendous sound. Yes, they are a little heavy, but unless you are 70 or want to jog with them, them are probably a good choice. I upgraded my electronics that were driving them from a few hundred dollars to a few thousand and they scaled and were up to the upgrade each time. I just recommend reach for as good a quality as you can afford, it will likely be worth it, and provide years of listening pleasure.
