sonci
- Apr 3, 2008
Since you are a Rush fan I`m posting my opinions as well,
I wouldn`t worry of Kmixer, unless you are using XP,
Using directsound has its advantages, such as not messing with ASIO drivers which smt can be a pain in the ass.. as you said there`s no big difference after all, the same as comparing Flac with v0, we know flac is better, but not always we can distinguish them,
also if you have a bright sounding system, directsound can help a bit in "warming", Asio usually is too analitical, while wasapi, well I dont use it unless written on soundcard box "wasapi compatibel"..
The Omega card should be fine, (though never tested it), in fact I dont think there`s much difference between soundcards at that price levels, but in HeadFi 80% of recommendations go for an Asus card, the rest for Creative, and Audioengine monitors, just marketing..
