dj_mocok
- Dec 26, 2003
Other lenses that are more versatile than 18-55mm are of course, 18-70mm or 18-135mm.
Not necessarily more versatile, but there are quite a few more zoom lenses which are pretty good around those ranges, too lazy to remember each one of them. eg. you have Tamron 28-75 f/2.8, 17-50 f/2.8, Nikon 35-70mm, etc... There are many options to choose from, depending on your personal preference (and willingness to spend).
Did you also have a look at Canon range? Canon 400D is ridiculously affordable now compared to a few years ago when 350D was introduced. But I'm not that familiar with Canon lenses, but Canon is worth considering since it can also perform very well and cheaper than some Nikons.
I don't know, this is just from out of my head and looking through the lens selection - from what I see, looks like you can also consider something like 400D body only + 17-40mm f/4L USM? (this combo both new maybe cost around US$1,600-ish? that's quite good value IMHO) **edit: add: I just had a look at the samples from that 17-40mm, to my eyes, properly used, this lens deliver superb image quality, contrast and sharpness are top notch. **
Or do you mind to get used ones? Maybe a 20D or 350D or something?
If some of the lenses are too expensive, you can always get the Canon body and then get a Sigma or Tamron lenses. Really, there are so many combinations you can do if you are starting from scratch. There are a few Canon users here, I'm sure they can give you information about the camera or lenses.
Originally Posted by Eagle_Driver /img/forum/go_quote.gif The combo would be quite nose-heavy, in this case. However, I don't need any focal length above about 100mm. Perhaps I should get a body-only version of the next model up (D40x or D80) and something a bit more versatile than the 18-55mm kit lens? |
