davidsh
- Oct 4, 2012
I haven't yet heard any plausible reason why higher or lower impedance is better.
Increasing the length of a run of wire will increase impedance, but you should have more copper to work with.
Keeping the impedance low, however, can result in higher current and a stronger magnetic field.
You could use a thicker gauge wire (lower gauge number) to keep impedance low while still giving you plenty of length.
But using a lot of heavy wire could weigh down the diaphragm and mess up the response you were looking for.
I am not a transducer designer, so all of the above points are just speculation, but I believe that they are at least somewhat valid. A real designer would not only be thinking about these, but dozens of other design variables that will alter final response. In the end, a headphone's impedance is just a reflection of some of the choices the designer made.
The only point I've read that *might* offer an advantage to high impedance headphones is the one about noise floor. Otherwise, a consumer only needs to worry about impedance so that one can properly power the headphones one chooses.
Are you suggesting that there are no other benefits of higher impedance headphones beyond, now antiquated usage in the studio? Can we say with that in some way impedance is responsible for some aspect of the quality of sound. Perhaps better way to phrase the question would be to ask if someone would take impedance (particularly higher impedance) into consideration when choosing headphones.
That's because the question is incomplete.
The better question answers "Better for what?"
Headphone/earphone listening has evolved into a number of different things, and there should be best choices for each thing.
But you got to say what the thing is!
