Difference between Push-pull and Balanced
Feb 10, 2012 at 4:45 PM Thread Starter Post #1 of 15
Tilpo
Aren't these two one and the same, in reality? I know push-pull is mainly used when describing amplifiers, whereas balanced is mainly used for describe cables.
Feb 10, 2012 at 4:57 PM Post #2 of 15
Google/Wiki:
http://en.wikipedia.org/wiki/Push%E2%80%93pull_output
http://en.wikipedia.org/wiki/Balanced_output
Feb 10, 2012 at 5:00 PM Post #3 of 15
Google/Wiki:
The reading of that is the very source of my confusion. I quote from the push-pull article: "The two antiphase outputs are connected to the load in a way that causes the signal outputs to be added, but distortion components due to non-linearity in the output devices to be subtracted from each other". Isn't that the very definition of balanced?
Feb 10, 2012 at 5:00 PM Post #4 of 15
Balanced here is used to refer to each channel (left and right) using its own amplifier circuit, rather than a single stereo amplifier, it is two stereo amps. The cabling is only in reference to them having to be separated (no shared grounds).
Push pull refers to how each of those amps can work. I think, for instance, an amp with an active ground, could be considered push-pull. But two active grounds (one per channel) would be balanced.
Feb 10, 2012 at 5:52 PM Post #5 of 15
Nope. Have you seen the schematic in the wiki article where the load is driven by the two output devices?
With balanced audio you have two conductors of the same type with equal impedances .. in other words there is no conductor that is connected to the ground / no common return for both the left and right channel.
I guess you have noticed that these are two separate things. Therefore asking about the difference between the two doesn't make much sense. Push-pull is a type of electronic circuit and balanced audio is a way of interconnecting equip.
Feb 11, 2012 at 5:06 AM Post #6 of 15
Ah I see. I thought this was the case initially, but the line I quoted in my previous post made me confused.
Feb 11, 2012 at 12:56 PM Post #7 of 15
Well, "push-pull" is really a set of different types of amplifiers that share one particular characteristic - encompassing some class A amplifiers and all class B (and class A/B) amplifiers.
"Balanced" audio is in fact a type of electronic circuit as well.  Unfortunately, it can refer to several different things...  A traditional double-entry headphone cable with four conductors up to the TRS plug is in fact balanced, as are transducers (i.e. speaker/headphone audio drivers) - they both reject common mode noise (although not from before the plug).  The same goes for speaker cables and speakers, of course.  The key is that unwanted noise imparted equally on both sides of the cable results in no change in voltage differential over the transducer - thus the noise is cancelled out.
Differential signaling is what is usually called a "balanced amplifier".  It means that you actually have two sets of amplifiers amplifying a signal and driving the load in that manner, but in opposite polarity of each other.  Interestingly enough, this is exactly the same principle as a push-pull class A amplifier that has a common ground - it's just implemented at a different point in the amplifier topology.
In a push-pull class A amplifier with common ground, an output transformer after two tubes (or rarely, transistors) working in opposite polarity to each other actually adds the opposite polarity signals back together with the same polarity.  That is, only one of the two cables to the transducer is "hot" with the audio signal (the other being the ground) - even though the signal is both "pushed" and "pulled" before hand.  If you remove the output transformer that combines the two signals together with like polarity, you've just created a balanced amplifier which is often still referred to as a push-pull amplifier (I'm not sure if that use of the term is correct or not).  Note that class B amplifiers are different and you can't convert one from common ground to balanced just by changing the output transformer configuration, like with a push-pull class A type.
Of course, you could always have a balanced push-pull class A amplifier that combines the two principles.  That would be two of the push-pull class A amplifiers I just described (each a pair of tubes/transistors with a transformer combining the opposite polarity signals), but working in opposite polarity to each other - one on each side of the transducer.  You're just combining two amplifiers - and in fact, this is exactly what bridging an amplifier is (i.e. a bridged amplifier is a balanced amplifier).
Remember, the transducer only cares about the voltage difference across it - so if in a balanced amplifier the signal is +9 V on one side (from the amplifier working in normal polarity) and -9 V on the other side (from the amplifier working in negative polarity), the transducer sees it the same as a normal non-balanced +18 V on one side and 0 V on the other (ground).  That's the basic idea of a balanced amplifier.
So the exact application of the term "push-pull" can be rather wishy-washy (I didn't even address class B biased amplifiers, which are of course different than push-pull class A amplifiers, balanced or not), and such an amplifier can be both "push-pull" and balanced.  I don't care so much for word games, but I hope I've cleared up some confusion.
The most important distinction to a consumer is whether an amplifier is balanced so there's no common ground, or unbalanced so there is a common ground.  You definitely don't want to short together the black/negative terminals on a balanced amplifier.  This is particularly important in a couple of cases - most notably that Polk SDA speakers cannot use non-common ground amplifiers under any circumstances.
Feb 11, 2012 at 1:35 PM Post #8 of 15
Does this mean if you have a balanced (no common ground) amplifier but only single ended headphones - you could not simply make a converter cable that combines the (-) pins into a common?
Feb 11, 2012 at 1:59 PM Post #9 of 15
technically "balanced" headphone amps with 2 amps per channel are "bridged output" - and no you can't use them with TRS - they absolutely require 4 wire connection
Feb 12, 2012 at 7:09 AM Post #11 of 15
nice post, I was wondering when someone might get it right and you did, mostly....but for this one detail. there is actually a distinction between bridged and balanced, one that seems to often be missed on this forum as many of the amplifiers promoted as balanced here, are actually just bridged.
in a bridged amplifier, you can achieve 'balanced' output from 2 single ended amps tied together, but each signal phase in the amp is still referenced to ground and may even be made up of all N or P channel devices. Some call this balanced simply because the amp is fed a +/- differential signal and the signal is floated on the output to the headphones and ground ignored. In this example even if the 2 signal wires are antiphase, this is still just a bridged amp.
in a balanced amp the differential signal, made up of in-phase and anti-phase components, is generally fed to a differential pair of N-channel and P-channel devices like jfets, mosfets, or perhaps bipolar NPN and PNP transistor devices. the signal is not referenced to ground, but to the opposite phase, the only connection to ground is through the power supply. there are also balanced in/out IC's, although not all that many, more are designed to be ADSL drivers, or LVDS receivers/transceivers, rather than audio amplifiers
then you have special cases like Circlotrons and cross-coupled Balanced single-ended (X'd) amps like those from Nelson Pass that can use all P or N channel devices due to non-standard feedback mechanisms, but lets not go there
Feb 12, 2012 at 12:55 PM Post #12 of 15
Thanks for the correction.  I knew there was a distinction between bridged and balanced amplifiers but I had no idea what it was!  As far as users are concerned they both are differential output amplifiers - I think that's important to note.
Nov 14, 2013 at 9:22 PM Post #13 of 15
This thread really should be titled, "Difference between push-pull and single-ended," or "Difference between balanced and unbalanced."
This a single-ended amp with balanced output. The KT88 is definitely being used as a single-ended amp but the speaker side of the output transformer is not grounded and appears to me as a fully balanced output and would offer matching impedance on the + and - speaker outputs so it would offer common mode noise cancellation.
Here's a push-pull amp with unbalanced (common ground) output. Note the ground symbol on the speaker tap at far right. Technically it would be incorrect to describe a headphone cable connected to its output as a single-ended cable. Calling it an unbalanced or common ground cable would be more correct:
In layman's terms, the opposite of push-pull is single-ended and the opposite of balanced is unbalanced or common ground.
Nov 15, 2013 at 11:09 AM Post #14 of 15
I think most of us think of a "fully balanced amp" as having three properties:
1. Balanced input meaning identical impedance in the positive and negative inputs (so common ground between the left and right channels cannot be used).
2. Balanced amplification meaning complete separation between left and right channels so no common ground in the amplifier circuitry (dual differential or dual push-pull amplification is normally used).
3. Balanced output meaning identical impedance in the positive and negative transmission lines (so common ground cannot be used).
Each of the 3 can be implemented independently:
An amp can have unbalanced (common ground) input with balanced push-pull amplification with balanced or unbalanced output.
Some amps have balanced input with single-ended amplification & common ground with balanced output.
Nov 15, 2013 at 11:44 AM Post #15 of 15
Much care must be taken to design a properly balanced amplifier, so usually you just see some bridged amps but symmetric signaling isn't even a requirement of balanced operation.
And:
Quote (Rod Elliott):
For many applications, the use of balanced interconnects is simply not needed at all. In general, a home hi-fi needs balanced interconnects like a fish needs a bicycle, but someone, somewhere, decided that balanced connections "sound better", but not because of noise reduction. Balanced connections are not used because they sound better or even different from any other. They are used where mains earth (ground) noise causes (or may cause) interference to the signal.
