chaotic_angel
waiting for report owner to pair it with heavy planar headphones please
LCD-X driven with ease. Absolute no problem here.waiting for report owner to pair it with heavy planar headphones please
Bass is there, yes, for sure. Pounding as it should be. IIRC from my listening session, I would say already at pretty low volume, maybe 30% on low gain. Let me check tonight again.bass is there? at what vol? @F700
I actually have the same question. AFAIK, Anson did not say something specific about that. The Calyx M allows playing with both volume pot, which is very handful. The Final E5000 being very power hungry, I set the Calyx M on Mid gain, to approx. 75% and then do the rest with the HA-2.Does anyone know if Anson said something about the gain, whether it would be better to use it in low or high gain, if for the plugged in headphone both is possible? I am listening with the Stellia through Calyx M and can change the quantity of the sound output on the DAP. Right now I have more output on the DAP but low gain on the HA-2 (volume pot is on 3 o'clock). But I could also lower the output of the Calyx M and put the HA-2 on high gain and just push it up to 11 o'clock. Which one is better? Is there even a sound difference (such as in bass reproduction/authority)?
I am having my Xduooxd05plus (with burson V5idual) DAC/AMP, it is also well known for its power, any comparatiom please?
helo @eyan still look forward to hear your impression please..
Whichever sounds best to you sounds best .... to you.Does anyone know if Anson said something about the gain, whether it would be better to use it in low or high gain, if for the plugged in headphone both is possible? I am listening with the Stellia through Calyx M and can change the quantity of the sound output on the DAP. Right now I have more output on the DAP but low gain on the HA-2 (volume pot is on 3 o'clock). But I could also lower the output of the Calyx M and put the HA-2 on high gain and just push it up to 11 o'clock. Which one is better? Is there even a sound difference (such as in bass reproduction/authority)?
I feared you might say thisWhichever sounds best to you sounds best .... to you.
Since the opamps of the HA-2 are also changeable, I wonder how other opamps would sound with it? Maybe someone who has know-how can test the amp with different opamps in the future?Got the chance to do a quick side by side with the XDuoo XD-05+ with a Burson V5i-D. The place was a bit noisy so I can't really comment about sonic differences much.
We used a ToneKing TO600 (600 ohms, 105 dB sensitivity). On max gain and max volume on both the XD-05+ and HA-2 the XD-05+ gives greater volume based on my ear-meters. The XD-05+ sounds warmer compared to the HA-2. The rest of my impressions would be next to meaningless so I'll leave with those observations.
HTH.
many thank @eyanGot the chance to do a quick side by side with the XDuoo XD-05+ with a Burson V5i-D. The place was a bit noisy so I can't really comment about sonic differences much.
HTH.
