Yes, that works fineAnyone running the H1 off an Apple Ipad? I know the IPhone works with the USB Camera kit, but the IPads all have USB-C not thunderbolt.
Dethonray Honey H1 - USB DAC/AMP
- Thread starter F700
BadgerRivFan
I would dearly love to update the firmware in my H1 to hopefully resolve the volume jump when in high gain. I struggle with computer basics and just can’t figure out how I get a new downloaded firmware file on my device. Can you advise me how I get from here to here…
daorenmi
- Mar 14, 2014
There is a Google drive link which contains a pdf with explanations and the toolsI would dearly love to update the firmware in my H1 to hopefully resolve the volume jump when in high gain. I struggle with computer basics and just can’t figure out how I get a new downloaded firmware file on my device. Can you advise me how I get from here to here…
https://drive.google.com/drive/u/0/mobile/folders/1aKAL-TBoO04u5lKkyDUW6yOGTtiXvDNO?usp=sharing
eskamobob1
- Nov 16, 2011
use the charging port to update the firmware, not the USB audio one
daorenmi
- Mar 14, 2014
Your pc recognised H1, so you should run flymcu.exe then chose serial port and honey 3.9.hex. There’s a doc about fw upgrade,follow it step by step.
BadgerRivFan
I appreciate all the replies, I really do… but I am stuck here:
I know how to follow directions, but I don’t know enough about computers to know how to troubleshoot this stuff
eskamobob1
- Nov 16, 2011
Which port are you plugged into on the honey? Your computer should be plugged into the charging port of the honey to update the firmware.
BadgerRivFan
Plugged into the charging port.Which port are you plugged into on the honey? Your computer should be plugged into the charging port of the honey to update the firmware.
BadgerRivFan
I figured it out... I was not inputing the file to install (duh). It's working, but the high gain volume issue is not resolved, do one of the other options (other than 3.9) work better? I use the Honey with IEMs...
eskamobob1
- Nov 16, 2011
If yoy use with iems there is an iem tubed firmwareI figured it out... I was not inputing the file to install (duh). It's working, but the high gain volume issue is not resolved, do one of the other options (other than 3.9) work better? I use the Honey with IEMs...
BadgerRivFan
Yes, just installed that one and I think it will work for me.If yoy use with iems there is an iem tubed firmware
Thanks all! And yes, I know you're not my IT department, but the help is sincerely appreciated.
eskamobob1
- Nov 16, 2011
Oh dude. Dont feel bad in the slightest asking for it help on a device in its thread. Thas a huge portion of what I even use headfi for myself tbh
daorenmi
- Mar 14, 2014
Great! That’s the reason we stay here!Yes, just installed that one and I think it will work for me.
Charlyro222
Just ordered H1.
Is there anyway to know firm version when arrives?
Thank's in advance.
Thank's in advance.
