Dethonray Dtr1 Prelude high resolution player
Sep 15, 2021 at 12:59 PM Post #1,966 of 2,404
Did you get a tracking number for the early bird or the package just showed up?
I myself asked Anson to give me my tracking number but whole week it showed that the package is still in Honkong and not shipped yet, only today I got notification from DHL that my package is on the way and I will receive it on Monday, who knows maybe my unit was in the making.
Sep 15, 2021 at 11:08 PM Post #1,971 of 2,404
Received mine yesterday too. First thing I noticed is that my USB-C iPad charger wouldn't charge it. Odd because it charges everything else I have. Changed the charging brick and everything worked fine. My advice: try different charging sources first.
I found out about two weeks ago upon receiving my DTR1+ that the adapter box seems to have compatibility issues with USB-C PD power supplies. I tried all my PD power supplies with USB-C output using C-to-C cable and none of them worked. However using a non-PD power supply with USB-A output, via USB-A to USB-C cable to feed the DTR1+ adapter box, would work fine. I reported this to Anson back then and I believe he's already found where the issue was and has since made design changes to the adapter box. I think the DTR1+ units shipped recently already ship with the new version of the adapter box.
Sep 16, 2021 at 10:11 AM Post #1,974 of 2,404
I very interesting compare old DTR1 with new DTR1+.
And any upgrade firmware to old DTR1 with new function like DTR1+.
Sep 16, 2021 at 10:51 AM Post #1,975 of 2,404
Just installed the newest DTR1+ firmware 1.2 that came out tonight. This version brings two nice and welcome improvements: (1) Automatically compensates for the 6dB level difference between DSD and PCM source files; (2) When switching to a different output level, the default volume will be 20 for all modes, except for the highest Extra High mode which defaults to 10.
Sep 16, 2021 at 11:15 AM Post #1,976 of 2,404
Just installed the newest DTR1+ firmware 1.2 that came out tonight. This version brings two nice and welcome improvements: (1) Automatically compensates for the 6dB level difference between DSD and PCM source files; (2) When switching to a different output level, the default volume will be 20 for all modes, except for the highest Extra High mode which defaults to 10.Is the
Sep 16, 2021 at 5:24 PM Post #1,979 of 2,404
DTR never seen by PC, USB is only to charge not transfer files. Your must use card reader to transfer files on SD.
