ngoshawk
- Dec 13, 2015
Correct. I only have the HA-2 & DTR1, hooked with the dual 3.5 cable, when I use both.You have HA2 if I have not misunderstood .....
I meant Oyaide, not Furutech, my badSee, this is where my findings differ. Of course they do have to be well braided, but they do sound different, too. Not that much to hear with my Calyx M but that changed when I got my LPGT ti, where I can hear quite a difference between those small cables. Funny thing is that a cheaper cable (although from Oyaide) is better sounding (or has a better synergy) than my 400 dollars Palladium interconnect, at least with my amp/headphone. That’s why I also bought (again) that interconnect I sold you last year hahahaha, and now also the Furutech you mentioned. Just to play around a bit and try figuring out which one works best. In the Future I also might wanna look into the Romi Audio interconnects. Thanks for that tip buddy
No problem. They both are top notch. Thing is: Now I do hear differences. That’s a nice thing. Maybe because of the added resolution? Doesn’t matter. Something to play with (again). Oh, this hobby isn’t boring at allI meant Oyaide, not Furutech, my bad
Difficult to say. It just changes the sound enough for me to notice it. Of course not night and day. But if you know your source (with the amp) well, you perceive a slight shift. At least I do with my setup. Also my Palladium plated OCC silver headphone cable might help in that regard. It’s super resolving.In what terms do you feel the difference? In the sense ..... by changing the cable between DAP and Amp, does the musicality of the dap change or some of its nuances? It's interesting .....
How does the sound change between the two amps you posted?
either of these with DTR are amazing. (white is a Pure II+, black is a Duo II)
I would say the Pure II+ has a little bigger staging and more 'open' sounding. The Duo is denser. It has a two-stage bass boost, Stage 1 also seems to boost treble a little, as well, Stage 2 moves the bass more into the middle of the picture and is probably 'dedicated bass-head only' territory. In common they both have this feel that reminds me of a good tube guitar amp head pushed into distortion, they have this very euphonic feeling of power, an even-order harmonic kind of sound. Sorry, hope that is not thread-jacking. Bottom line is that the DTR sounds really good with both.How does the sound change between the two amps you posted?
HA 2 instead while increasing the power ... Does it always keep the low range of the DTR1 neutral and a bit analytical? I am not a lover of the low range ..... So maybe over HA2 what comes close is more the DUO and not Pure II+?I would say the Pure II+ has a little bigger staging and more 'open' sounding. The Duo is denser. It has a two-stage bass boost, Stage 1 also seems to boost treble a little, as well, Stage 2 moves the bass more into the middle of the picture and is probably 'dedicated bass-head only' territory. In common they both have this feel that reminds me of a good tube guitar amp head pushed into distortion, they have this very euphonic feeling of power, an even-order harmonic kind of sound. Sorry, hope that is not thread-jacking. Bottom line is that the DTR sounds really good with both.
I have not heard HA 2 to compare. Also, I am not sure what you were saying about the bass? Neither of these are purely transparent, they both to me enhance the bass a little in quality while the Duo increases quantity. The DTR all on its own has incredible dynamics, throwing the Vorz into the chain seems to improve the spatial imaging.HA 2 instead while increasing the power ... Does it always keep the low range of the DTR1 neutral and a bit analytical? I am not a lover of the low range ..... So maybe over HA2 what comes close is more the DUO and not Pure II+?
I had the Duo II once. Sold it. HA-2 is much more resolving and cleaner sounding. Much more power too. I preferred it by quite a margin over the Duo II, that’s why I sold it after hearing the HA-2HA 2 instead while increasing the power ... Does it always keep the low range of the DTR1 neutral and a bit analytical? I am not a lover of the low range ..... So maybe over HA2 what comes close is more the DUO and not Pure II+?
