Alberto01
- Mar 23, 2012
Deleted post......I had not noticed that you were referring to the AH-C400 instead of the AH-C300.
I just ordered a pair and I was planing on using them with a galaxy s4 active and a fiio e17. Do you guys think that would be a good combination?
Absolutely. I'm running mine directly out of the S4 and it sounds awesome...like the hammer of Thor beating on your eardrums![]()
But in a good sorta wayThe S4's great so you should get some decent sound from it... But if you coupled that with the Fiio E12 Mont Blanc, and you'll be blown away when you flick the Bass Booster switch...
The only bad comment that I have read on the sound quality of the AH-C300 is here in this thread. It is from Eugguy saying that these have sharp treble. From all other comments online, and I have searched quite deeply, it seems like these have an awesome sound even for audiophiles. It seems like everything on their sound profile ranges between very good and excellent. That makes me wonder why don't we see more reviews and comments as compared to other IEMs for which there are more negative reviews. In other words, if these are so awesome, why aren't more people buying them even taking the risk of not getting a good fit and having to sell them later or just putting them away? An awesome sound is worth the risk. Something doesn't fit in this picture. There aren't enough people raving about how good these sound, but everyone that tries them seems to find them awesome in SQ. That doesn't fit.
Hey Paul (ShooterMacG) and markjohnsonii!:
I joined the bandwagon and got me a pair of these. They already have more than 50 hours of use since I got them. How long is the burn in for these and what changes should I expect as a result of the burn in period?
The first thing that I did when I opened the box, was to remove the ear stabilizers. If you don't need them, don't use them. My ears ergonomics match very well with the AH-C300 shape, size and weight. I have medium size ears, but big (or very big) ear canals. They feel better than normal IEMs on my ears and they hold their place very nicely when I am using them. There is no need whatsoever for the ear stabilizers that make them look like an ear inspection device from your ear doctor. HA, HA.
The biggest change I found after extended burn-in time is when I use the amp with them. They sound more relaxed and richer when coupled with the Fiio amp... They can handle it better.
I didn't find too much difference after burn-in.
But you can reduce the base levels by using the solid silicon plugs or by not wearing the supports, add the supports and you'll see how much more base there is.
Hmmm.. I disagree about both of your comments. 1. People have said repeatedly that these get better with proper burn-in time, and I have experienced this first hand. 2. Most people don't get a good fit with the supports, which is the main compliant among buyers, and thus their bass will be diminished. Your experience is definitely a statistical outlier from the average user experience.
How do these compare to the FX700, FXZ200, CKS77X and the CKS1000?
Short answer: If you like a lot of bass- very favorably(especially for the price).
I'll elaborate more this weekend when I have time to do a good comparison.
