sajunky
Just match impedance of the cable, 75 Ohm if not mistaken.I have a T2 and Gaia , can i use cheap HDMI and cheap BNC, or better use cheap hdmi and better Bnc or vice versa ?
You certainly can, but I’ve found the HDMI and BNC cables to impact sound quite a bit - not necessarily better, but a different tonal balance.I have a T2 and Gaia , can i use cheap HDMI and cheap BNC, or better use cheap hdmi and better Bnc or vice versa ?
In my experience, between BNC and I2S cables, I can hear sonic improvement much more clearly with the I2S cable. Upgrading the BNC cables, in my case, improve the sound in a lesser degree.The power cords and the USB, HDMI and clock cables all impact the sound with this combo (as do footers). This has been true with all my gear from various manufacturers over the years so nothing new here.
Having said that, with the Denafrips DAC/DDC combos, even with cheap cabling everything still sounds very, very good and nobody should feel pressured here, but for those looking to further tweak, tune, change, enhance and/or possibly further improve things, if your budget allows... go for it! I did and I'm happy with the results.
Also, if you are not a believer in cables, that is 100% fine... nothing to see here, just go with specs and move along.
YMMV
True. Even more. With a clock connection between T+ and DDC, difference between AES (or S/PDIF) data connection and I2S is smaller, you save a fortune on the top audiophile quality cables. If there is a diference, then there is something wrong with implementation.In my experience, between BNC and I2S cables, I can hear sonic improvement much more clearly with the I2S cable. Upgrading the BNC cables, in my case, improve the sound in a lesser degree.
Un saluto. Sono interessato a D. e quindi sarebbe utile se potessi condividere l'esperienza "operativa" sia con Venus che con T + .... Sono sicuro che suona alla grande. Nessun problema di affidabilità,nessun problema di connessione o rumore ?.. Qualcuno sul forum D. (FB) parla di qualche problema di rumore, in T+,Venus e Pontus II, forse risolto con l'aiuto di Alvin....ho un'alta efficienza sistema (non sono un tipo headfone) e ogni piccolo problema diventa un "grande" problema .... spero nella tua opinione. GrazieDenafrips Terminator Plus Prime impressioni.
Immediatamente, l'aggiunta di questo alla mia configurazione è stato il più grande salto di qualità del suono mai realizzato. Immediatamente al primo ascolto ho notato texture e dettagli su brani che non avevo mai sentito prima. Di solito ci vuole del tempo prima che un componente si stabilisca prima di notare questi cambiamenti. Non questa volta.
Il palcoscenico è monumentale. Dà così tanto spazio agli strumenti per materializzarsi dal nulla. Ciò è aiutato dallo sfondo più scuro che ho sentito personalmente da un componente audio. Tutto arriva con più sicurezza rispetto al Venus II e non è nemmeno sottile. La musica suona viva. La minima quantità di sibilanti (se presenti) ascoltata su Venus II viene praticamente cancellata. Piacevole, potente, trasparente e risolutivo sono alcune delle parole che mi vengono in mente. È un'apparecchiatura seria che può trasformare il tuo sistema, a condizione che tu abbia il giusto livello di attrezzatura. Altezza e profondità sembrano illimitate. Accoppiato con il Susvara, il decadimento è su un altro livello con la voce che si insinua particolarmente in livelli inquietanti di trasparenza. Vale a dire durante l'ascolto di Lord of the Rings: Fellowship of the Ring Soundtrack a 24 bit, ci sono stati momenti in cui mi sono tolto le cuffie e mi sono seduto lì incredulo. Solo... la quantità di informazioni che c'è è sbalorditiva. Come se questo non creasse già dipendenza, Terminator Plus è un'ipotetica macchina per crack audio con una fornitura illimitata.
Posso capire perché così tanti lo recensiscono a pieni voti. È il miglior DAC che abbia sentito fino ad oggi e un notevole pezzo di ingegneria. Felice di far parte del club e non vedo l'ora delle numerose sessioni di ascolto che questo DAC eleverà sicuramente.
Sorry in English.......A greeting. I'm interested in D. and so it would be useful if you could share the "operational" experience with both Venus and T + .... No reliability problems, no connection issues or noise?... Someone on D.forum (FB) talks about some noise problem, perhaps solved with the help of Alvin .... I have a high efficiency system (I'm not a headfhone guy) and every little problem becomes a "big" problem .... I hope for your opinion. Thank youUn saluto. Sono interessato a D. e quindi sarebbe utile se potessi condividere l'esperienza "operativa" sia con Venus che con T + .... Sono sicuro che suona alla grande. Nessun problema di affidabilità,nessun problema di connessione o rumore ?.. Qualcuno sul forum D. (FB) parla di qualche problema di rumore, in T+,Venus e Pontus II, forse risolto con l'aiuto di Alvin....ho un'alta efficienza sistema (non sono un tipo headfone) e ogni piccolo problema diventa un "grande" problema .... spero nella tua opinione. Grazie
Thanks for the reply .. it's reassuring to know that everything is OK. I was a little worried reading the D.forum on FB. Venus (II) seems like a great choice (like theT,of course) and I'll try to listen in comparison with Holo Spr. and WLI have a Venus II for a few months and it has been working smoothly so far
I had Venus II DAC with no problems, very reliable, good quality DAC. If you are interestet, there is my Denafrips Venus II vs Holo Audio Spring 3 KTE comparison on "Holo Audio Spring R2R DAC" thread (post nr. 2720).Sorry in English.......A greeting. I'm interested in D. and so it would be useful if you could share the "operational" experience with both Venus and T + .... No reliability problems, no connection issues or noise?... Someone on D.forum (FB) talks about some noise problem, perhaps solved with the help of Alvin .... I have a high efficiency system (I'm not a headfhone guy) and every little problem becomes a "big" problem .... I hope for your opinion. Thank you
