How did you guys correct the latency issues of the pontus 2?
Denafrips 'Pontus' R2R ladder DAC - close up view
- Thread starter PitBul34
FooFighter
Which ones?How did you guys correct the latency issues of the pontus 2?
For watching movies?
Yeah and gaming.Which ones?
From AlvinYeah and gaming.
DENAFRIPS DAC uses adaptive fifo buffer, and reclocking. This technique yields excellent jitter rejection, however, the variable latency is inevitable.
If you have a good PC you might try this for gaming/video/youtube sessions
![1625424390248.png 1625424390248.png](https://cdn.head-fi.org/a/11527908.png)
I find that it becomes very noticeable in faster scenes. Does it bother you?From Alvin
If I use 8 samples I don't notice about any desync at all
sajunky
On the USB connection only very small buffer is required and no reclocking. Do you experience delays also on USB?From Alvin
Yes, I'm a gamer and you notice instantly
I talk with Alvin about this Kinki THR-1 problem and he put me in contact with responsible guy for Kinki in Vinshine, KenNow I have developed an irritating problem with the right channel of the Kinki THR-1 where some frequencies let me hear a noise, like a grainy noise very uncomfortable and upsetting..... I have to power off and power on and it will randomly show up..... I already contacted with Alvin and will look into fixing it up
They have offered me to repair the Kinki THR-1 and I only have to pay for shipping lol, the unit is 3 years old and out of warranty, I didn't even know it I bought it here in head-fi
These guys are next level
john57
- Feb 16, 2009
THe ASIO buffer size should have no effect because you are not using the ASIO driver when watching youtube, or any video using a web browser. You can see that ASIO is not active. You need to use applications that are ASIO aware.If you have a good PC you might try this for gaming/video/youtube sessions
I noticed that but I also tested it and it does use something related to the buffer size and it does affect the latency and therefore audio/video sync, test it yourselfTHe ASIO buffer size should have no effect because you are not using the ASIO driver when watching youtube, or any video using a web browser. You can see that ASIO is not active. You need to use applications that are ASIO aware.
CalvinandHobbes2020
The Pro-ject Stream Box S2 Ultra is based around a Raspberry Pi, but with power supplies and USB inputs optimized. I'm using one and it sounds quite good to me. I've not yet compared it to more expensive streamers, but did recently listen to a USD $7500 Naim NDX2 as a streamer feeding my Pontus. Just listening casually, I didn't hear anything obviously better about the sound quality from the Naim versus that of the Pro-ject. I'll compare the Pro-ject to more expensive streamers at some point (Innuos, Auralic, Aurender), but it's been a nice sounding and fairly inexpensive way to get into digital streaming.are all you guys streaming from PC/Mac or is anyone using a dedicated streaming box?
interested as my yet sent back blue sound node N130 streamer was sounding a tad off to me.
The high end streaming boxes like from NAD are costing a fortune.
Rasperry Pi solutions could be built by oneself but no dedicated audio components with noise/jitter filter available there as far as I know.
New IFI ZEN streamer looked interesting to me at first but though it seems to have some nice noise/jitter filters built in, it's otherwise a tad basic if you want to stream beyond Tidal/Spotify/Quobuz
Some changes I've made to my Pro-ject streamer setup that have improved sound quality.
1. Turned off Wi-Fi & HDMI. Using an Ethernet cable connected to an Ethernet Access Point created with a TP-Link RE230 Wi-Fi Extender
2. Added a Audioquest Jitterbug to the USB output to my Pontus DAC
3. Using a Supra Cat 8 Ethernet cable
4. Using a Stordiau Lush USB cable.
Some commentary from the designer of the Pro-ject streamer: ttps://www.avforums.com/threads/why-is-pro-ject-stream-box-ultra-s2-so-expensive-700euro-for-an-r-pi.2175090/
FooFighter
Thx!The Pro-ject Stream Box S2 Ultra is based around a Raspberry Pi, but with power supplies and USB inputs optimized. I'm using one and it sounds quite good to me. I've not yet compared it to more expensive streamers, but did recently listen to a USD $7500 Naim NDX2 as a streamer feeding my Pontus. Just listening casually, I didn't hear anything obviously better about the sound quality from the Naim versus that of the Pro-ject. I'll compare the Pro-ject to more expensive streamers at some point (Innuos, Auralic, Aurender), but it's been a nice sounding and fairly inexpensive way to get into digital streaming.
Does it support Tidal Connect?
Guess same limitations here as for any PI volumio implementations up to now such as no Amazon Music HD and Apple Music lossless support, right?
CalvinandHobbes2020
It does support Tidal, but I'm not sure if it supports Tidal Connect. It does not support Amazon Music HD or Apple Music.Thx!
