BTW, is the new sound signature applied only to PCM input, or both PCM and DSD?
DENAFRIPS FPGA Firmware Update (12TH Anniv.)
- Thread starter alvin1118
according to the instructions: Yes.can it be done in mac ?
I made an old Windows 10 notebook do the job, though.
Can i get back to original firmware for Terminator 2 ?
after the update the sound skip all the time when using I2s and clock out .
Check in the webpage where you downloaded the new firmware from and look for more than 1 firmware, maybe 1.0 or something like thatCan i get back to original firmware for Terminator 2 ?
This is what we got for the Pontus
ThxCheck in the webpage where you downloaded the new firmware from and look for more than 1 firmware, maybe 1.0 or something like that
DrCal
- Feb 4, 2009
Did you configure I2S after update? Update resets I2S pin configurationCan i get back to original firmware for Terminator 2 ?
reydelanada
Today I upgraded my Terminator + to latest firmware using an M2 macbook air. No problems at all. Smooth upgrade. Configured clock and i2s after to match again my Gaia DDC.
I spent like 2 hours of critical listening to well known tracks and I liked the change. Looks like it gained even more detail and "life". Hard to tell without an A/B test but quite happy.
Yes , i configure the I2S .Did you configure I2S after update? Update resets I2S pin configuration
after the update left and right was reverse, so i have to configure the I2S.
I have the same experience left & right dsd channel swap. After run thru 000 to 111, seem like dac 111 setting is correct but need swap dsd channel. DDC remain 000.Yes , i configure the I2S .
Alvin, Please Help.
Already back to firmware 1.0 , still have the skips .
CAJames
Alvin, Please Help.
And you’ve tried all the different I2S pinouts?
YesAnd you’ve tried all the different I2S pinouts?
Now I brick the terminator 2
DrCal
- Feb 4, 2009
Have a problem with T+. Only USB input works now, I2S is dead. Tried various configurations and no luck
DrCal
- Feb 4, 2009
Now going back to 1.0 hope it restores I2S ….
